only thing that is different is the location of the top rear a-arm mount on the frame. what will happen is the top of the tires on the back will tilt like this / \ instead of the normal \ / that they do with a lift.but with the BIG lifts it gets real bad i guess. i would think you could modd the lift to work , maybe just drill a new hole to help straighten out the tire..?
08 650H1 LE Warn 3.0 Snorkeled,Rad relocated Custom mounted gauges muffler tweaked Dynojet, slide mod, spring clipped Custom clutch kit, 4.0 gears 2" lift, HL springs, HL spacers "G" axles 29.5 Laws on custom LE wheels 30" MLs on Black Castle Roks 05 500m Dynojet,slide mod spring clipped muffler tweaked Hidden snorkel HL temp gauge 26" 589MTs on ITP type 6s Hard.Pack.Arctic.Cat
