Flywheel advance key
All Forums >> [OEM Discussions] >> Polaris >> Flywheel advance key Page: [1]
Flywheel advance key - 9/26/2008 6:04:40 PM
Inman
Bought one from bikeman, is it worth putting it in, and how big of a job is it? Thanks
08 Renegade 800
06 Polaris 450
06 Polaris 700
TEAM CREEK BOTTOM #69
RE: Flywheel advance key - 9/26/2008 6:42:44 PM
fatdaddy700
makes a diffence.
(BLACKOUT)
POLARIS 2002 700
6" P.B.S. LIFT
32"****S
VISION 161 CHROME RIMS
50% GEAR RED.
HEELCLICKER CLUTCH KIT
CERAMIC COATED 800 HEADER
AAEN MEGA POWER PIPE
HIGHLIFTER RADIATOR KIT
HIGHLIFTER TEMP. GAUGE
HIGHTLIFTER PRO BELT
CUSTOM AIR BOX
CUSTOM SNORKELS
CUSTOM PAINT
****PROP SHAFT
TURNERS H.D. BALL JOINTS
TURNERS H.D. TIE RODS
TURNERS BRASS BRAKE PADS
(MORE THAN MEETS THE EYE)
STAGE 2
6" RACKED REAR END.
74.8 HP 800 (HOTSEAT PERF.)
(in reply to Inman)
RE: Flywheel advance key - 9/26/2008 7:20:02 PM
cletus600twin
It took me about 20-30 mins to install.  And yes it is worth it.  I noticed that the engine reved quicker and I could get to my top end quicker. You will need a flywheel puller and torque wrench and an impact wrench for the install.
04 600twin blue, ITP Mud Lite XL's on Polaris Vision Bruiser wheels, Highlifter front and rear springs, Heelclicker clutch kit, 800 primary, K/N air filter, Dynojet kit, fan override toggle, reverse override toggle, Automoter electonic temp gauge,custom rear rack(diamondtread), 800 header pipe, Pure Polaris (White Bros) exhaust, Polaris front cargo box, front brush guard, rear bumper, 8" stainless steel atv nuts, SNORKLED finally!
(in reply to fatdaddy700)
RE: Flywheel advance key - 9/27/2008 7:11:51 PM
Eville700twin
The first one I changed took me about about 45 min. Now it takes me about 20 min. Here is a really good write up with step-by-step instructions and pics. Timing Key InstallThe flywheel on my 02 was really stuck on there good. I had to take a 3 lb sledge to the puller. Don't be afraid to whack it good.
As far as the difference, it depends on the amount the key is offset and supporting mods. The one I am running now is .05" and I notice good increase of throttle response. I have to run 93 oct now because I get really bad spark knock with 87.
2002 Polaris Sportsman 700
HL HD Springs
2" HL Lift
Front Ape Legs
Heel Clicker
Warn 2.5
.05" Timing adavance
UNI Air Filter
DynoJet Stage 1
28" Outlaws
(in reply to cletus600twin)
RE: Flywheel advance key - 9/27/2008 9:12:36 PM
Inman
Thanks
08 Renegade 800
06 Polaris 450
06 Polaris 700
(in reply to Eville700twin)
0.219
