jrpro130
it's really simple tap into the acc from the 12v accessory plug, run that to the supply of the switch (one side), run a wire from the switched (other side of switch) to the positive on the fan. Ground the switch if necessary (if it has an led), and your good to go! I run it on all the bikes
Blue 07 Grizz 700FI -Audiopipe-Snorkels-Radiator Relocate-29.5" Laws on SRA Offset ITPs-Backrest-2" Lift-G-Team Axles-Ricochets-HMF and Optimizer-A few things here and there...
