Fan Switch
Fan Switch
All Forums >> [OEM Discussions] >> Kawasaki >> Fan Switch Page: [1]
Fan Switch - 8/27/2008 4:37:56 PM
nadep python
I have been chasing down electrical problems all afternoon regarding the on/off switch for my fan.  I finally narowed it down to the switch, I can flick it on and off about 100 times and it comes on maybe 3 times out of the 100 so in my infinite electrical visdom I think that is the problem.  What kind of switches are you guys using and is this a common problem?
Thanks.
08 Kawi Brute Force 750 FI
27'' Bi/Tri Combo mounted on BlackITP SS108
Snorkles
Relocated HL Super Radiator
HL Temp Gauge
ASR X-Series Tierods
Rox Risers and Solex CR High Fat Bar
Twin Air filter
VFORCEJOHN stage 3 goodness
Bison front bumper
3000lb Viper winch
"It takes a College Degree to break em and only a High School degree to fix em."
RE: Fan Switch - 8/27/2008 5:04:54 PM
ALMOST30S
MIne is just a regular looking chrome switch that will turn the fan on if pushed up or down,(middle is off) nothing special
Team MUD PIMPZ!
1984 yamaha breeze brute force 500
lift-f150 torsion keys up front and 2inch blocks in the rear
SCUBA GEAR
30x12x15 big horns
flowmaster exhaust
cookie cutter cdi
APC headlights
Transmission work
RIMs-u wont believe it!ROUND ONES!how crazy is that?
Peg leg limited slip 4wd lock
smitty built brushguard
Flux capacitor motor puttin out 19 rwhp!
(in reply to nadep python)
RE: Fan Switch - 8/27/2008 5:11:31 PM
devildog12210
I am just using a regular plastic switch from Advance Auto Parts. It has been submerged a few times and it has never failed me.
(in reply to ALMOST30S)
RE: Fan Switch - 8/27/2008 8:18:17 PM
Shock69
+1 with devil dog.
make sure none of ur connections are corrded and everything is nice n tight...
BFWDP
2006 Silver Brute Force 750
****. 800 Big Bore Kit
-Silp On HMF
-K&N air filter
-dyno - Jet Kit
-28 Mudzilla's - 12X7 Douglas Wheel Rattle snakes
-Custom Built Snorkels
-2 inch HL lift kit
-CopperHead VDI CDI
-EPI Clutch Kit
-Temp Gauge
http://www.flickr.com/photos/22851534@N04/
(in reply to devildog12210)
RE: Fan Switch - 8/28/2008 2:12:25 AM
ryanlt
part of your problem could be the fact that most small switches like that are only rated for low amps. the fan is probably pulling more amps that the switch can handle. you can run your hot wire straight to the fan from the battery and put the switch on your negative wire. this way there is no current flowing through the negative wire but yet it still breaks the circuit to make the fan cut off and on. this is kinda the same thing we have to do with alot of high amperage stuff at work, put the switch on the nuetral. maybe this will help ya out a little.
< Message edited by ryanlt -- 8/28/2008 2:14:06 AM >
05 Brute 750
Lime green
29.5 laws
SuperGrip sra wheels
HL 2'' lift
HL relocated radiator kit
HL outlaw clutch kit
HMF
K&N
Rejetted
Snorkeled- twin air snorkels
Moose CDI
Custom tunes
(in reply to Shock69)
RE: Fan Switch - 8/28/2008 10:20:01 AM
devildog12210
mine is a 30 amp if that helps any?!
(in reply to ryanlt)
RE: Fan Switch - 8/28/2008 5:35:28 PM
EZRIDER lets rock
I have been using switches by GB sold at lows for years now, momentary as well as on/off/on and just on/off switches.....they have a rubber cap that you can screw on it after its mounted, I use some liquid tape in a can to paint around the switch after I have the wires on them, I put 3 coats on them and just a lil bit around the rubber cap before I screw it on to help seal it, not one switch in 7 years has ever failed yet and one of the Honda's I had was submerged past the handle bars a few times.
somebody hold me beer, I got to go get
mario,s he,s broke again!!
WWMD???
RE: Fan Switch - 8/28/2008 8:09:48 PM
nadep python
Put a new switch on this afternoon electrocuted my self in the process.  If this one fails on me I saw a "waterproof" one in a boat store I might try out.
Thanks dudes.
Snorkles
HL Temp Gauge
Twin Air filter
Bison front bumper
3000lb Viper winch
(in reply to EZRIDER lets rock)
0.391
