FI Light coming on instead of temp light
All Forums >> [OEM Discussions] >> Kawasaki >> FI Light coming on instead of temp light Page: [1]
FI Light coming on instead of temp light - 8/16/2008 10:06:13 AM
redbrute_08
I let a buddy of mine drive my bike and he just went down the road about 3 miles and the bike run hot and shut down. The temp light never came on the only thing that came on was the FI light. He said he pulled it over as soon as it came on, but it shut down as soon as he pulled it over. He said that the bike started losing power before the light come on. I checked the airbox and it had 1" of oil in it. Well I have it at the dealership now getting rebuilt and they are claiming that they are getting the temp light to come on. I was just wondering why it did not come on when he was riding it
2008 Brute Force
HMF Utility
Power Commander
Wiseco pistons
Mudbuster Hotcams
RE: FI Light coming on instead of temp light - 8/16/2008 10:37:19 AM
chipBlaster
sure it overheated? and not something else wrong in th FI?
08 team green Brute Force 750
LRD torc pipe
optimized
let 'er eat
(in reply to redbrute_08)
RE: FI Light coming on instead of temp light - 8/16/2008 10:54:55 AM
redbrute_08
Yeah the overflow was dumping radiator fluid.
2008 Brute Force
HMF Utility
Power Commander
Wiseco pistons
Mudbuster Hotcams
(in reply to chipBlaster)
RE: FI Light coming on instead of temp light - 8/16/2008 11:11:15 AM
devildog12210
The light itself may be functioning fine but the sensor may be bad. I would check that and make sure it was functioning. Either way you are screwed. When you get it back be sure to run a manual switch to the fan. It is a life saver just be sure to turn it off in deep water. All of this is also solved by relocating the rad to the rack. Sucks your having to go through this.
RE: FI Light coming on instead of temp light - 8/16/2008 12:07:05 PM
SSTOGI
If the coolant is low and the tip of the temp sensor isn't submerged in coolant it will not give you a reading. The fan will not come on and it will overheat , but, the light should have come on because the sending unit for the light is in the thermostat housing. It may be faulty.  How are they getting it to come on? If they are just jumping the wire then the sending unit still could be bad.
BF750 BUILT FOR BUSINESS
THE NEW MUDINMYBLOOD FORUM
MUDINMYBLOOD SWAG
MUDPERFORMANCE FORUM
(in reply to devildog12210)
RE: FI Light coming on instead of temp light - 8/17/2008 1:54:16 AM
j08BRUTEenFORCEr
mine did the same thing at mud nats this year.  temp light never came on but the FI light was flashing like crazy.  and it started running like crap also.
Of course I can........ ITS A BRUTE FORCE DANGIT!!!!!
TEAM D SQUARED SPRING, TX
2008 Super Black brute force 750i
FMOS Built Motor
WARN 2.5xt winch
center snorkled
HID 10000k headlights
custom audio-pipe speaker box
HL 2inch lift
29.5's on ITP C type 7's
and a cooler full of beer!!!!!!!
THE LOANER
08 Kingquad 750 efi: yosh pipe, snorkled, outlawed
(in reply to SSTOGI)
0.797
