rc2atvs
ORIGINAL: TRLWGN1 quote:
ORIGINAL: rc2atvs every so often you have to adjust the actuator cable as it gets alil stretched. on left side sitting on quad behind the inner fender, connected to the diff is the actuator. has a cable going throughing a oblong metal rod. its easier to remove the front part of the skid and look at it from underneath,and to make adjusments. maybe my 03 is different, but I just adjusted my cable this past weekend and the adjuster was up top, behind/under the speedo cover. 8mm wrench and 10 mm wrench. Works just like an adjuster on a manual clutch cable. i guess i could be wrong or we are both right b/c the adjustments underneath is like a clutch/brake adjustment also.
07 black 450kq itp ss112's w/27" mst's ,itp 106 w/27"laws, uni-filter,dyno-jet programmer, yoshi slip on,warn rt3000,elite front bumper,epi clutch kit,a-arm skids,bison rear bumper,hl springs,hl 2" lift,custom snorkels, coop mod, gorilla rear axles,chillin w/engine ice and strobes 06 black celebration eiger w/warn winch/bumper/front skid,and 26" itp xtr's itp type7 wheels,2" hl kit,epi clutch kit, zuki rear bumper 96 suzuki lt80 lightweight douglas aluminum rims,and maier front plastic/li
