EXHAUST SNORKEL?????
All Forums >> [Most Popular Discussions] >> ATV Accessories >> EXHAUST SNORKEL????? Page: [1]
EXHAUST SNORKEL????? - 6/17/2008 10:33:55 PM
John56_TMBz
ON A HMF HOW CAN I MAKE A SNORKEL ON THE EXHAUST????
RE: EXHAUST SNORKEL????? - 6/17/2008 11:02:04 PM
kingquad300
i think it invlovs a little cut chop rebuild lol
i think you can just cut the tip off and weld to that
Main Ride: Izzy
Grizzly 600
belt snorkled
motor intake snorkled
oil cooler re-locate
HMF (Polished)
carbonfiber fan overide switch
2 Inch lift front and rear
Jetted (Again and again and again)
oil temp guage
wheel spacers (1.5 inches all the way around)
bored 40 over
29.5 Swamplites on sum full moons
pull'en them w/o a clutch kit
split stero (2 6 1/2's & adding 8 incher fo that thump)
(in reply to John56_TMBz)
RE: EXHAUST SNORKEL????? - 6/17/2008 11:04:38 PM
John56_TMBz
OK MAN, THANKS.
(in reply to kingquad300)
RE: EXHAUST SNORKEL????? - 6/17/2008 11:09:24 PM
BowtechnYamaha
Find you a peice of exaust tubing that will fit in the tip. Get a exaust clamp and some high temp silicone and that will keep you from cutting on that high dollar exaust.
I aint got time to live and learn, its time to churn and burn!!!
2007 Blue Yamaha 660
28x9.5 Outlaws
Custom Build Heavy Duty Bumper
3000lbs winch
Radiator relocated
Belt snorkels
Air box snorkel
Future mods
8" lift
HD axles
2005 Bowtech Allegiance
29" Draw Length
and a blistering 319 F.P.S
2000 Ford F-150 X-cab
3" body lift
33x13.50x17 Super Swamper IROKS
Flowmaster exaust
Throttle Body Spacer
LEA
RE: EXHAUST SNORKEL????? - 6/19/2008 10:46:55 AM
olyeller
unscrew the stock tip on the HMF and go to a hardware store. they should have a spacer that is the exact same size as the stock tip. get 2 of these. place the stock tip over the spacer and make a mark where the three bolts will go. use a drill press to punch the holes in all 3 spacers. if you know someone who works at a muffler shop, the next part will be easy. go to a muffler shop and get them to bend you a pipe to the height and angle that you are looking for. once you've done this, put a spacer on where the stock tip was on the HMF, align the bolt holes, put the pipe up to the spacer so you can make sure the snorkel stands straight up, then use a welder to tack on the pipe to the spacer. now remove the spacer and pipe from the HMF and finish welding the pipe to the spacer. put a line of high temp silicone around where your exhaust snorkel will bolt on, then bolt on the snork. you now have a removable exhaust snorkel that you can take on and off and you want. any other question just pm me or alan_smith
'06 350 Rancher
Highlifter 2" Lift Kit
Highlifter Springs
Highlifter Stick Stompers
Custom Snorkel
HMF Pipe
Custom Bolt-On Exhaust Snorkel
Dyno Jet Kit
27" Carlisle Ag Tires
(in reply to BowtechnYamaha)
RE: EXHAUST SNORKEL????? - 6/20/2008 6:49:12 PM
alan_smith
ORIGINAL: olyeller
  I have a write up that I will get to you as well as some pictures.  I'll try to post the write up tonight and some pictures tomorrow!
Alan Smith
2000 4x4 Honda 350 Rancher ES
  • High Lifter 2" Lift Kit
  • High Lifter Lift Springs
  • 27x9.5 Outlaws (front)
  • 27x12.5 Outlaws (rear)
  • 12" ITP SS112 wheels
  • (4) Moose 1" Wheel Spacers
  • High Lifter Rear Disc Brakes
  • HMF Utility exhaust
  • K&N Air Filter
  • Outerwears Pre-Filter
  • DynoJet Jet Kit
  • Custom Intake Snorkel
  • Custom Exhaust Snorkel
  • Outlaw Super-Duty Clutch Kit
  • Pull Starter Leak Shield
    (in reply to olyeller)
  • Post #: 6
    RE: EXHAUST SNORKEL????? - 6/21/2008 3:21:36 PM
    alan_smith
    Here is a link to the write up with pictures that I was discussing.  Check it out and let me know if it helps and if you have any questions.
    http://www.highlifter.com/forum/m_2734710/mpage_1/key_/tm.htm#2734715
    Alan Smith
  • K&N Air Filter
  • DynoJet Jet Kit
    (in reply to alan_smith)
  • Post #: 7
    RE: EXHAUST SNORKEL????? - 6/25/2008 11:50:28 PM
    IwishIhadSnorkels
    Ive been thinking about buying one for my 07 king quad 700. can you get detachable exhaust snorkels????
    07 king quad 700
    25'' 589's
    front and rear custom bumpers
    metal skids
    working on my snorkel troubles
    2 in. lift
    07 king quad 700
    front and rear bumpers
    back seat
    metal skids
    2 in. lift
    RE: EXHAUST SNORKEL????? - 6/25/2008 11:58:57 PM
    alan_smith
    Look at the link that I posted.  It is how to make a detachable exhaust snorkel.  A little reading will get you a long way...
    Alan Smith
  • K&N Air Filter
  • DynoJet Jet Kit
    (in reply to IwishIhadSnorkels)
  • Post #: 9
    RE: EXHAUST SNORKEL????? - 6/27/2008 8:39:22 PM
    IwishIhadSnorkels
    thanks
    07 king quad 700
    2'' lift
    custom front and rear bumper
    metal skids
    25'' 589s
    getting snorkels for the airbox, cvt, intake and exhaust
    pictures comming soon :)
    RE: EXHAUST SNORKEL????? - 6/29/2008 7:49:55 PM
    alan_smith
    ORIGINAL: IwishIhadSnorkels
    thanks
    Hope that helps, if you have any questions let me know.
    Alan Smith
  • K&N Air Filter
  • DynoJet Jet Kit
  • Post #: 11
    RE: EXHAUST SNORKEL????? - 8/15/2008 7:56:18 PM
    GrizzlyMud
    hey i tried your idea and it worked great!! thanks
    pictures coming soon!
    0.688
