06HondaRubicon
Hondamechanic on here has an online manual, I'm sure he'll chime in and help you out. I just know about the code 5 cause mine has been to the shop NUMEROUS times for it. They finally determined that it was a failed connector for the angle sensor, once they replaced that mine has operated fine.
2006 Honda Rubicon -Custom Fiberglass Stereo System 1982 Honda ATC 200E "Big Red" 1995 Red Honda 300 4x4 ("The Tank") -355 BBK, 459 Cam, HL clutch kit, Spool Locker, Vesrah valves and springs, D.I.D heavy duty timing chain, Thrush exhaust, Fully Snorkeled, K&N Filter, Dynojet kit, metal cage floorboards, Foreman 450 shocks on front and back, 2" lift and 1.5" Spacers on the rear, All rear offset ITP Black Delta Wheels, 28x12.5 Outlaws on all four corners
