Moose1217
ORIGINAL: BUSHHOG Moose1217, it's not about enough power. The Outty has that in spades. It's about the correct RPM to more easly find the best power range. If you ride a lot of thick mud our clutch kit will help. When you are at a dead stop in deep, thick mud is where the clutch kit really helps. The reason is the kit gives you a higher RPM engagement point delivering more torque to get moving. It also helps the belt not to slip as bad. Our lift kit seems to work OK on your model ATV and not cause to much stuff to break when combined with monster tires, but does not mean you can't break stuff. However, understand if you drive smart you will lower the risk of breakage. Lifts and big aggressive tires when combined with heavy thumbs, poor driving skills, a big ego and two six-packs of beer do break a lot of stuff.......lol. Another item you need if you don't already have one, is a snorkel, as water gets into your system easy. Thanks bushhog, that's the info. I was looking for regarding the clutch kits and the lift. I knew the motor could turn them easily, but was worried about burning up the belt from too much slippage if I really needed one. I wish you could say your lift was better for the Outtys, but as long as you are condoning it with smart driving skills, I'm still sold on it. Hopefully, those Deer Lease trips won't get too out of hand...lol BTW, why did the price of the tires and the lift kit recently go up?
2008 Outlander 800 XT, camo K&N filter with Precharger Aftermarket HID look headlights 2" HL Lift Kit 29.5" Laws on SS108 rims (black) Riccochet skid plates Exhaust, programer, and clutch kit to come!
