engie
This is an idea that originated from Suzuki FI systems. Apparently AC models their systems almost directly after Suzuki... All you need is a papercip. Bend the paperclip straight. Now look under the seat and find a six prong "output" connector(three rows of two). This will be a white connector with a black cap on it. Remove the cap. Be sure the bike is cut off before proceeding. Now, notice the location of the wires actually entering this connector. There will only be four wires entering into the six connectors. Your interested in the outside connectors that each have a wire running to them. One side will, the other side will have an empty prong. Put the paperclip into both of these connectors(the outer ones with wires), and effectively "short" the two wires together. Turn the key on. From there, one of the following codes will be read. Whether your quad reads AC or EC before the number is irrelevant. Suzuki FI will say EC while Arctic Cat FI will say AC. The numbers are what matters. Here are the codes. AC00 NONE AC12 CRANK POSITION SENSOR AC13 INTAKE AIR PRESSURE SENSOR AC14 THROTTLE POSITION SENSOR AC15 ENGINE COOLANT TEMP. SENSOR AC20 RELAY (DIFF LOCK RELAY) AC21 INTAKE AIR TEMP. SENSOR AC23 TIP OVER SENSOR AC24 IGNITION SIGNAL (IGNITION COIL) AC32 INJECTOR SIGNAL AC40 IDLE SPEED VALVE AC41 FUEL PUMP CONTROL SYSTEM You can also check the alignment of the Throttle Position Sensor, to ensure it is set within specification. If it's not, you will experience midrange performance problems. It is determined by the line on the left while in diagnostic mode. You want the line to be in the middle of the A or E, not at the top or bottom. If it's at top or bottom, you need to adjust your throttle cable to get it within spec. NOTE: The thundercat may be slightly different and have a AC33(or something similar) because it has a second injector to monitor. I have yet to see a service manual to confirm one way or another. Thanks to NYROCatv for the illustration...
Team Throwed Offroad crew chief Currently building 4 race motors and awaiting the class breakdowns to start on the rest!!! quote:
A second place trophy is only useful as a doorstop!
