DOES 2'' LIFT PULL AXLE OUT OF CHUNK
All Forums >> [OEM Discussions] >> Can-Am BRP >> DOES 2'' LIFT PULL AXLE OUT OF CHUNK Page: [1]
DOES 2'' LIFT PULL AXLE OUT OF CHUNK - 8/27/2008 9:29:16 PM
big J 75
I WANT TO PUT A 2'' HL LIFT ON MY 08 800 OUTLANDER BUT HAVE HEARD ALOT OF PEOPLE HAVE HAD PROBLEMS WITH THE AXLE POPPING OUT OF THE REAR END IS THIS SO  AND WHATS THE CURE FOR THIS I HAVE A PIPE LIFT ON THE FRONT NOW TO KEEP IT FROM SAGGING BUT WANT A LITTLE MORE
08 CAN-AM OUTLANDER STEALTH SNORKEL 29.5 LAWS 06 500 FOREMAN SNORKLED LIFTED AND LAWED 07 RINCON SNORKLED LIFTED AND LAWED
RE: DOES 2'' LIFT PULL AXLE OUT OF CHUNK - 8/27/2008 9:33:00 PM
007BF
I would not add a bracket lift to the rear if thats what you are asking about.  You will have problems with the axles popping out.  All you can do is a pipe lift on the rear to eliminate the sag.
I-45 RACING
powered by Pit Proven Performance
Russell Coker #55
Texas A&M class of 07'
WHOOOOOP!!
C.M.R POINTS SEASON FINAL
1st OPEN/PRO SWAMPCROSS
1st CLASS 1 MUD BOG
3rd CLASS 2 SWAMPCROSS
3rd CLASS 2 MUD BOG
(in reply to big J 75)
RE: DOES 2'' LIFT PULL AXLE OUT OF CHUNK - 8/27/2008 9:58:01 PM
Quackman
I put on a 2" HL lift kit and basically it is a 2" spacer (pipe lift) on the rear shock and I have not had any issues so far in about 10 hrs use, it it helps.
Quackman
CAN-AM 800 XT Camo
Full Skid & CV
2" HL Lift
Stealth Snorkel
Heated Handgrips
2007 Yamaha Grizzly 350
Wife's-Stock for now
(in reply to 007BF)
RE: DOES 2'' LIFT PULL AXLE OUT OF CHUNK - 8/27/2008 11:00:23 PM
sdf1201
ORIGINAL: 007BF
Agreed. I have a 2" on the front and a pipe lift all the way around and have had zero issues.
08 Prowler
08 Gade
07 Outty 800 FOR SALE
(in reply to 007BF)
RE: DOES 2'' LIFT PULL AXLE OUT OF CHUNK - 8/27/2008 11:05:08 PM
ndependent
WIth just the lift in the front and the pipe lift in the back, does the front look a lot higher than the rear? Does anybody have pics of this setup?
07 CAN AM OUTLANDER
A FEW EXTRAS!!!!
(in reply to sdf1201)
RE: DOES 2'' LIFT PULL AXLE OUT OF CHUNK - 8/27/2008 11:08:09 PM
sdf1201
ORIGINAL: ndependent
here's mine with a 2" and pipe lift in front and a pipe lift in the back with 28x9.5's
08 Prowler
08 Gade
(in reply to ndependent)
RE: DOES 2'' LIFT PULL AXLE OUT OF CHUNK - 8/28/2008 8:17:46 AM
got wake?
2" difference in GC front to rear:
i've got a 1.25" bracket lift in the front (custom made) and works shocks all around.  the GC is nice in the front, but i'd like an inch or two more in the rear.
RE: DOES 2'' LIFT PULL AXLE OUT OF CHUNK - 8/28/2008 8:19:31 AM
CANADAM
what is your ground clearance?
2008 outlander 800
29.5 laws on chrome wheels
snorked
(in reply to got wake?)
RE: DOES 2'' LIFT PULL AXLE OUT OF CHUNK - 8/28/2008 9:35:39 AM
justgotwickid2
2" Highlifter bracket lift on front, and nothing on the back.
2008 Can-Am Outlander 800
29.5's
SS106's
HL Lift
EPI Clutch Kit
HMF Pipe
Gen. III Programmer
(in reply to CANADAM)
RE: DOES 2'' LIFT PULL AXLE OUT OF CHUNK - 8/29/2008 2:56:36 PM
bushhog750
will the pipe lift all the way around cause any problems and will it lift the bike at all
08 outlander 800 red- MaD Cannon tuned- snorkled- vented- itp ss212's black- 29.5" outlaws- power commander- hmf pipe- uni filter- pipe lift- 6orilla radiator relocate- ricochet skid plates- xt front bumper- coolanol radiator fluid- crankcase vent mod- amsoil fluids- sponsored by VISA and 60 hours a week.
(in reply to justgotwickid2)
RE: DOES 2'' LIFT PULL AXLE OUT OF CHUNK - 8/29/2008 4:23:05 PM
got wake?
ORIGINAL: CANADAM
15" front, 13" rear   i really want to lift the rear up more.
RE: DOES 2'' LIFT PULL AXLE OUT OF CHUNK - 8/29/2008 9:10:03 PM
big J 75
i have a pipe lift in the front to help a little it sags bad without them so bad that the 29.5's hit the headlight bucket and almost tore of my front grill the pipe lift helps but it still hits when turning ond hitting a bump at the same time i want to go as tall as i can without any trouble i may use the vid from MR.CAN-AM JOHN CANNON he used some small angle to make a bracket lift for the front he really knows these bikes
RE: DOES 2'' LIFT PULL AXLE OUT OF CHUNK - 8/29/2008 9:26:50 PM
got wake?
yeah, john made a good video of making your own brackets.  it will definitely help in the front.  i just wish we could do something like that for the rear   i made a solid aluminum bracket for mine:
Thumbnail Image
Attachment (1)
RE: DOES 2'' LIFT PULL AXLE OUT OF CHUNK - 8/30/2008 10:46:13 PM
bushhog750
so the pipe couplers all the way around won't lift the bike it just gets rid of the sag in the spring. But if I put the pipe couplers all the way around the rear axles won't pop out of the diff either. Is this correct.
RE: DOES 2'' LIFT PULL AXLE OUT OF CHUNK - 8/30/2008 11:04:01 PM
got wake?
yup.  the pipe lift just preloads the springs more, which will give you more GC, but a rougher ride.  you might want to check out the HL springs.  they don't sag and ride nice, from what i've heard.
(in reply to bushhog750)
RE: DOES 2'' LIFT PULL AXLE OUT OF CHUNK - 8/30/2008 11:19:04 PM
forfree81
the only way to get more lift in the rear is longer rear axles. the only problem is the rear tires will get closer to the rear foot well.
can-am 800
pipe lift, gor***a radiator kit, eastcoast snorkles, 29.5s, leaking belt housing
RE: DOES 2'' LIFT PULL AXLE OUT OF CHUNK - 8/31/2008 12:01:41 AM
bushhog750
What size are the pipe couplers. I was looking at my shock and thought it was about 1.5" am I right. Thanks. I just bought my 800 outlander a week ago and I got tires and wheels coming and want to go ahead and stiffen the springs up before they get here.
(in reply to forfree81)
RE: DOES 2'' LIFT PULL AXLE OUT OF CHUNK - 8/31/2008 7:16:08 AM
got wake?
yeah they are the 1.5" couplers.  if your rear shocks aren't very worn out, i would suggest cutting one in half and putting that in the rear before doing a full pipe lift in the rear.  my '07 only needed half a pipe lift in the rear to fully extend the shocks.  its the fronts that usually sag the most and need the full pipe lift.
0.563
