Custom lift guys
Custom lift guys
All Forums >> [Most Popular Discussions] >> Tech Questions >> Custom lift guys Page: [1]
Custom lift guys - 11/14/2008 9:26:02 PM
UtilityRider51
What kind of steel rod/pipe do you guys use for A-Arms, Also what size?
thanks!
2005 Suzuki Eiger 400 auto 4x4
Warn 2.5
Custom A-Arm Skids
Custom Full Skid
Twin Air
Airbox snorkel
26-10-12 outlaws
26-12-12 outlaws
HL 2" Lift Kit
Tractor Muffler
RE: Custom lift guys - 11/21/2008 4:18:36 PM
kyleh87
on my friends yamaha he used square tubeing he extended everything a foot.lol it is massive.
2000 honda300
2in lift
30in mudlites/itp112wheels/chrome/black
homemade snorkle/UNI air filter
1-1/2 rear spacers
dyno jet kit
2005 honda forman 500 <sold>
2in lift
28in vampires/itp112black/chrome
(in reply to UtilityRider51)
RE: Custom lift guys - 11/21/2008 11:12:13 PM
mkp08
any pics?
Kawasaki 06 Prairie 360
12 in.itp ss108
26 inch outlaws
hmf pipe
jet kit
silver bars
LED headlights
not sold yet
700 prairie still mostly stock
airfilter
outlaws
HL 2inch lift
Warn front bumper
Baja lights
1989 250R
secret.
(in reply to kyleh87)
RE: Custom lift guys - 11/22/2008 2:51:09 AM
mud_duck
DOM, also called mechanical tubing.
'04.5 Polaris
TEAM CRUSHLOK Powered By Miller Industrial
CLICKMy Pics
______________________________________________
I may be old, but I'm not boring
(in reply to mkp08)
RE: Custom lift guys - 11/22/2008 2:58:15 AM
mud_duck
Here's a set of a-arms we built the other day. This is a temporary set only intended to make 2 races. I don't remember off the top of my head what we used (I bought the stuff , but I'm getting old) I know I had to go to a steel yard to find it. Not somthing you can get at Home Depot.
We will build a complete set of a-arms after the next race and those will be made out of DOM/mechanical tubing.
< Message edited by mud_duck -- 11/22/2008 3:00:42 AM >
'04.5 Polaris
CLICKMy Pics
(in reply to mud_duck)
RE: Custom lift guys - 11/22/2008 9:44:16 AM
camo650
I used 1 inch DOM.
East Coast Dirty Boy's/ TEAM SRA
Supporting East Coast Dirty Girls
http://www.flickr.com/photos/11635644@N04/
PARTING OUT 05 BRUTE 750 check the swap shop
SPONSORED BY LOUDERVISION
RE: Custom lift guys - 11/22/2008 10:49:08 AM
countryboy21
DOM tubing
ASYLUM ATV CLUB
(\__/)
(O.o )
This is Bunny. Copy Bunny into your signature to help him on his way to world domination
03 660 Raptor Moose handle bars with new spider grips.
K&N airfilter
dyno jet kit
sidewinder sprockets front and back
Yamaha aftermarket pipe.
lowered
(in reply to camo650)
RE: Custom lift guys - 11/22/2008 12:30:32 PM
mud_duck
  • WORKABILITY - Drawn Over Mandrel is a cold drawn electric resistance welded tube with all flash removed. Compared to structural pipe, DOM Round Tubing is produced to more exact OD and ID tolerances and better finishes without a seam. Ideally suited for a wide range of structural and bushing applications. Widely used in stressful applications requiring higher quality, uniformity, strength, and soundness.
  • APPLICATIONS - Farm implements, construction equipment, racecar frames, motorcycle frames, automotive parts, off-road accessories, etc
'04.5 Polaris
CLICKMy Pics
(in reply to countryboy21)
RE: Custom lift guys - 11/22/2008 3:47:45 PM
catkrazy
wow! found this just at the right time. Been inquiring about it on a another forum.
Are you extending out the upper shock location or fabricating a extended bracket using the sock upper mount holes?
Also, are you keeping the same geometry of the quad?
I think I remeber seeing somewhere that for every inch you go down with your arms(for lift) you go out 1/4" with the length of the arms?
Thanks
"OLD SKEWL" Lil Ole 03 500iM, Locker'd, Lift'd, Law'd, Pipe'd, Snorkle'd, Rad Relocate'd, Clutch'd, Jett'd, Filter'd
Gori!la'd, Spacer'd, 4.0 Gear'd, and one Kick A$$ Gear Reduction!
RE: Custom lift guys - 11/23/2008 7:15:24 PM
catkrazy
ORIGINAL: mud_duck
Are yall keeping the same geometry? And do you go by a formula for finding the width you want your arms based on the height?
Thanks
RE: Custom lift guys - 11/24/2008 3:38:44 PM
2000trx300
mud duck   what kind of bike is that on??
1995 HONDA 300 4X4
snorkled
355 BBK
459 cam
clutch kit
locker
2000 honda fourtax 300 2x4
stock
snorkeled
26 inch superlites
(in reply to catkrazy)
RE: Custom lift guys - 11/24/2008 5:28:08 PM
bansheefan03
its a polaris
2006 rhino 660
98 300
376 bbk,4.5mm stroked crank,ported head,ids2,snorkle,lift,body lift,locker,EDL/ silverbacks ,axle paddle,459 cam,gear reduction,clutch kit,warn 424,chrome XL2 wheels,katana oil cooler,400ex carb
98 300
8" lift, ape axles,gear reduction,xl2 wheels, axle paddle,high compression piston, clutch kit,459 cam,big red timing c
(in reply to 2000trx300)
RE: Custom lift guys - 11/25/2008 8:07:52 PM
JCSKINNER
A triangle formula http://ostermiller.org/calc/triangle.html. How do you know how long to make you axles.
http://www.mymudspace.com/WhiteTrashOffroad
!!!IF PARTS AREN'T FLYIN THEN YOUR NOT TRYIN!!!
This was EDITED in one of my replys
-NO firearms: The sale or trade of firearms in the Swap Shop is prohibitted. Again, any topics or replies pertaining to the sale/trade of a firearm will be removed immediately.
< Message edited by elkbow -- 12/3/2
1)Why is HIGHLIFTER ANTI-GUNS???
2)AND do some people have no life and look for stuff just to COMPLAIN
(in reply to bansheefan03)
RE: Custom lift guys - 11/25/2008 8:52:10 PM
greg mcmullen
a lot of custom builders buy the axles first and build the lift to fit them.
TEAM GORILLA powered by CAN AM!!
2008 Can Am Renegade: Turbo, NOS, Stretched, 7" Gorilla Lift, Gorilla Axles, 30" SBack Tires, ITP SS Wheels, Gorilla Snorkel, HMF Exhaust, DJ Power Commander,
FOR SALE!! PM ME FOR DETAILS!!
(in reply to JCSKINNER)
RE: Custom lift guys - 11/25/2008 9:09:02 PM
mud_duck
It's a polaris 700. It started out with a Gor!lla lift. We just raked it back a bit. If I like the wheelbase, We will make it wider. The shocks will mount differently on the wider a-arms.
'04.5 Polaris
CLICKMy Pics
(in reply to greg mcmullen)
RE: Custom lift guys - 11/25/2008 9:11:55 PM
mud_duck
ORIGINAL: catkrazy
We fabricated mounts that use the swaybar mounting location, since I have no swaybar this was easy.
'04.5 Polaris
CLICKMy Pics
RE: Custom lift guys - 11/25/2008 9:38:30 PM
catkrazy
ORIGINAL: mud_duck
ORIGINAL: catkrazy
Ok thank you!
RE: Custom lift guys - 11/26/2008 1:01:06 PM
marine6132
How long would a axle be for a 6 in lift on a polaris ranger??
RE: Custom lift guys - 11/26/2008 6:44:19 PM
mud_duck
That sounds like a question for gmack.
'04.5 Polaris
CLICKMy Pics
(in reply to marine6132)
