Custom Snorkels On Rancher 420 Post Pictures
All Forums >> [OEM Discussions] >> Honda >> Custom Snorkels On Rancher 420 Post Pictures Page: [1] 2   next >   >>
Custom Snorkels On Rancher 420 Post Pictures - 11/30/2008 8:04:43 PM
stilltippin863
Please Post Pictures Of Custom Snorkels On Honda Rancher 420
i mean pictures of it all the way from air box to where ever it goes
and list everything you needed to make the snorkel
see right now i am stuck
i had a snorkel made all out of PVC but i needed to take out my air box one day and i had to cut to snorkel and it was cockeyed up front anyways so i cut it all out now
i got a 1 1/2 inch pvc pipe comeing out of air box in orginal place with a 90 and a little peipe of pipe and another 90  and just got the factory hose and bushing to clap that in so when i need to take out air bbox just un do it and pull the pipe out
and useing adapter (rubber) from 1 1/2 to 2 inch claping that down and then connecting a piece of flex hose about 1 foot and running that into a 90 and going up useing a 45 and another piece of pipe to another 90 and another ppiece of pipe to a cupling outside of plastic and conntect the snorkel  not done yet with it i will try to take pictures tommorrow
if someone else has a better idea please help me out
and i was wondering how does people get to pipes coming out b/c that is hardly no room to work with that
please post up
RE: Custom Snorkels On Rancher 420 Post Pictures - 11/30/2008 9:53:01 PM
Brabus_atv
don`t do that
use something like that
< Message edited by Brabus_atv -- 11/30/2008 9:54:57 PM >
HONDA TRX 420 FE8
/CUSTOM 2" SNORKEL/EXTENDED VENT LINES/ Moose protection/ Garmin 60Cx/ Kenda Bear Claw 25"/ ITP SS 212/ ATV 200w MTX Sound system/Hella Optilux + Xenon 4200k/Tamarack T-3000/Heated Grips/Strobe Lights/
(in reply to stilltippin863)
RE: Custom Snorkels On Rancher 420 Post Pictures - 12/1/2008 8:01:19 AM
stilltippin863
yup that is the pipe i am useing but now i wondering how did you get that pipe to bend to go up by hand bars and then out the plastic??? that  does not bend very easy
and did you run that out of the air box ??
(in reply to Brabus_atv)
RE: Custom Snorkels On Rancher 420 Post Pictures - 12/1/2008 8:50:27 AM
stilltippin863
TTT
RE: Custom Snorkels On Rancher 420 Post Pictures - 12/1/2008 2:08:57 PM
Brabus_atv
i used 90 degree pvc angle or whatever this is called.
for the air box you'll need to cut off the stock pipe coming from it (leave about 10 cm) so you can glue a new pipe to it. it will get tight so you will need some silicon for rubber things in the airbox (you will see what i'm talking about once you have started)
to get it to the handle bars i just drilled a hole (drill a small one first than use a knife)
as well i need to find the way to hold the snork vertical because if you just get in the hole you drilled it looks like someone was drunk while doing that and it's leaning to the side still it does not affect top speed but annoys a lot)
it took me about two hours and 2L of beer to sort that
(it is really hard to paint pvc )
good luck !
HONDA TRX 420 FE8
RE: Custom Snorkels On Rancher 420 Post Pictures - 12/1/2008 6:40:19 PM
mud mulisha south ga
on mine we used 1 1/2 flex, it has no ridges on th inside of so that it dnt restrict air flow. also we used the factory rubber grommet and clamp the flex pipe slide right in. it dnt hurt to put some silecone around the grommet and the pipe just to cya, if u knw wat i mean!!!! the jur it like he has and if u use 2 hose clamps in wont lean or move at all for that matter.[IMG]http://i262.photobucket.com/albums/ii109/gamazduh/m_6b28ff0f70784e6ab3d1b921d25e9fa2.jpg[/IMG]
RE: Custom Snorkels On Rancher 420 Post Pictures - 12/1/2008 6:41:35 PM
hw do u post pics on here
(in reply to mud mulisha south ga)
RE: Custom Snorkels On Rancher 420 Post Pictures - 12/1/2008 8:43:53 PM
kjt4x4
i used some brackets that hole a 1.5in pipe to a wall to hold my snorks together better... not pictured here though.
07 420 Rancher ES 4x4
07 680 Rincon
http://s3.photobucket.com/albums/y60/KJT4X4/
RE: Custom Snorkels On Rancher 420 Post Pictures - 12/1/2008 8:49:15 PM
japickar
ORIGINAL: mud mulisha south ga
gotta make the "IMG" lower case (img)
2003 Honda Rancher- HL lift springs, Superstrapp IDS2, jet kit, K&N w/outerwears, ITP type 5's, 26/10/12 and 26/12/12 Swamplites
RE: Custom Snorkels On Rancher 420 Post Pictures - 12/1/2008 8:56:59 PM
kjt4x4
You can kinda see the two brackets together here.  It keeps them vertical always.
07 680 Rincon
(in reply to japickar)
RE: Custom Snorkels On Rancher 420 Post Pictures - 12/1/2008 8:58:10 PM
thankx japickar i appriciate it bro!!!
RE: Custom Snorkels On Rancher 420 Post Pictures - 12/1/2008 9:53:08 PM
stilltippin863
sorry but i will get my pictures up tommorrow it is kinda hard with me working 12 hour shifts 11 am to 11pm  but please when you post up pictures of your snorkels please post what all you needed to make the snorkels and show in depth pictures thanks alot
RE: Custom Snorkels On Rancher 420 Post Pictures - 12/1/2008 9:56:27 PM
stilltippin863
Brabus_atv
thanks alot them are good pictures
oh yeah i am running my out right infront of the steering wheel and i want to find out how to run dual snorkels like the camo 420 that is sweettttttttt but that is a tight place to work with
RE: Custom Snorkels On Rancher 420 Post Pictures - 12/1/2008 9:57:43 PM
kjt4x4
They are not true duals. One is the intake and the other is the vent lines.
07 680 Rincon
RE: Custom Snorkels On Rancher 420 Post Pictures - 12/1/2008 10:02:49 PM
kjt4x4
going into airbox.
across engine.
attaching through plastic
top of plastic.
07 680 Rincon
RE: Custom Snorkels On Rancher 420 Post Pictures - 12/1/2008 10:04:42 PM
lovnmud
yalls snorkles dont melt right there where its like 1/8 of ann inch from the motor???
_________________MUDAHOLICS_____________
2008 Rancher 420 es 4x4 camo
highlifter 2 inch lift kit
highlifter 2 inch wheel spacers
highlifter lift springs
10000k H.I.D kit
28 inch outlaws
highlifter xl2 alum. wheels
Power commander III
HMF pipe
snorkle
uni filter
audiopipe
other goodies......:)
______________"There is no cure"____________
RE: Custom Snorkels On Rancher 420 Post Pictures - 12/1/2008 10:07:42 PM
kjt4x4
I was scared it might melt.. but hasn't done anything to my hose yet.  over 30hrs with it on now and no problems what so ever.
07 680 Rincon
(in reply to lovnmud)
RE: Custom Snorkels On Rancher 420 Post Pictures - 12/1/2008 11:57:28 PM
stilltippin863
kjt4x4 where did you get that hose you are useing from?? it looks way more flexable then what we are using
< Message edited by stilltippin863 -- 12/1/2008 11:58:42 PM >
(in reply to kjt4x4)
RE: Custom Snorkels On Rancher 420 Post Pictures - 12/2/2008 2:53:56 AM
Goat1817
This is all the pics I have right now working on it when I get a chance Im going to start working on it this sunday so I will get better pics of how I ran it.
Myspace
1996 Blue Chevy Z71
3in lift & 3in body lift
315/75 Mastercraft Courser C/T on Helo Maxx 8 16''
2008 Honda Rancher 420 4x4
28x10x12 S-Backs on 12" ITP SS212 Machined
UNI
Stick Stoppers
3,000 Lbs winch
Custom Snorkel
Radiator Relocated
HL Temp Gauge
Black HMF Utility on the way.
1.5" wheel spacers on the way also.
Coming this winter
RE: Custom Snorkels On Rancher 420 Post Pictures - 12/2/2008 8:38:53 AM
stilltippin863
goat that looks reall good
(in reply to Goat1817)
RE: Custom Snorkels On Rancher 420 Post Pictures - 12/2/2008 9:26:52 AM
Brabus_atv
em.... scary
kjt4x4 i liked how you connected the pipe to air box looks safe (well done)
HONDA TRX 420 FE8
RE: Custom Snorkels On Rancher 420 Post Pictures - 12/2/2008 10:06:15 AM
Goat1817
Thanks but those pic was the first day i started working on it. I have a piece of angel iron that goes across in front of my pipes that i have put two u bolts to hold the pipe still then the angel iron is alos going to be holding my radiator up. I will get more pics this sunday like I said.
Myspace
1996 Blue Chevy Z71
UNI
Stick Stoppers
3,000 Lbs winch
Custom Snorkel
Radiator Relocated
HL Temp Gauge
Coming this winter
Post #: 22
RE: Custom Snorkels On Rancher 420 Post Pictures - 12/2/2008 5:27:36 PM
stilltippin863
i just do not understand how do you make the fake pipe for the air lines?? i mean how do you attach it to the plastic? see where i messed up is i put a 2 inch hole right in the center of the 4x4 so i have to use just 1 snorkel but i should have it  done here shortly  i just got to put a 90 and a 45  and a peice of pipe and then run it out of the plastics
Post #: 23
RE: Custom Snorkels On Rancher 420 Post Pictures - 12/2/2008 5:47:07 PM
kjt4x4
i used a male threaded fitting under the plastic and pushed it through the hole... then a female threaded fitting on top of the plastic.
My brother got the flex pipe at his work.  they have it for injection molding so its good with heat... doesn't melt.
< Message edited by kjt4x4 -- 12/2/2008 5:50:08 PM >
07 680 Rincon
Post #: 24
RE: Custom Snorkels On Rancher 420 Post Pictures - 12/2/2008 6:37:42 PM
stilltippin863
**** i wish i could find hose like that all i can find like that is that stuff for the pools and it is veryyyyy thin  so i did not even try to use it
Post #: 25
RE: Custom Snorkels On Rancher 420 Post Pictures - 12/2/2008 6:45:15 PM
kjt4x4
i'm sure you could find it in a hardware store maybe.
07 680 Rincon
Post #: 26
RE: Custom Snorkels On Rancher 420 Post Pictures - 12/2/2008 9:31:16 PM
stilltippin863
10-4 now i got a question i just got the male and female fittings out of the supply room at work ( I Can Get All That I Need HEHE ) i needed to complete my snorkel and  they do not screw all the way together did yours?? if not what did you use for a spacer so they will clamp tight against the plastic??
Or Is There A Kind That Does Screw All The Way Together I Will Check For Them Instead
Post #: 27
RE: Custom Snorkels On Rancher 420 Post Pictures - 12/3/2008 11:32:09 PM
stilltippin863
TTT
Post #: 28
RE: Custom Snorkels On Rancher 420 Post Pictures - 12/4/2008 6:24:18 PM
kjt4x4
ah no they didn't screw all the way together... but plumbers tape sealed up the threads quite nicely.  Mine has not leaked yet.  Now if you are running only one snorkel you might want to find some kind of plate to go under the plastic to support it some.  Or it might be fine.  One reason i put two of them was to use each of them to to support the other.  Mine did clamp tight against the plastic though with just the fittings.
07 680 Rincon
Post #: 29
RE: Custom Snorkels On Rancher 420 Post Pictures - 12/4/2008 7:35:52 PM
stilltippin863
yeah 10-4 i got some gaskets for hoses to put on the thread to take up the space to make it tight against the plastic and for the underneath of plastic i gunna get a peice of steel and use the plasma to cut it out and put the male tho it and then through the plastic  and then the female onto the male to hold it pretty good  i should have it done  at christmas b/c i think i get 2 days off hehe i got all the stuff for it but i have not even touched it in like a week or so  but i wil;l post pictures as soon as i get it done or when i get time
Post #: 30
Forum Software © ASPPlayground.NET
