C1iffBurton
is the crankcase vent the same on all bikes, on my carbed big bear it was originally tied into the intake tube going to the airbox, when i snorkeled i had to put it another place and i wanna say during mud nats i had the to put a fitting and a long tube and ran it up my snorkel which was fine no big deal, but it came off the left side of my motor and all my snorkel and vent lines came off the left also, when i made the vent line bend around back forward it made a nice semi halfway crinkle in the vent line, the entire nationals while running i ended up having to pull the vent line off the fitting and drain the water out of the vent line not sure if its the same with yall or what, the longer the vent line the harder itll be to keep it dry from the steam and heat....like i said im not saying much or actually saying im rite and none of yall are cuz yall are into these things way more than i am, but after mud nats i drilled a hole in my airbox and put the hose into there and siliconed it up, i have since then not had any residue in the line, it traveled like 8" when it was stock, then it was running like 3 or 4' when i first ran the line for mud nats, then after i ran it into the airbox its like 12" long so not far to travel at all but im sure yalls have alot more pressure going through them so it doesnt really matter the length of it at all anyways to all his own, run it the way yall want it run and let her rip
MINE*08 big bear 400, 27" skinny black love outlaws, CRSbear custom snorkel, Gumbo03 custom lift, oil cooler relocated, fan switch, audiopipe, viper 2500 max --TEAM ANYTING GOES RACING-- R.I.P. JAYSON MATTHEW PARKER
