Clutch Kit?? 07 660 Rhino (pls help)
All Forums >> [OEM Discussions] >> RUVs (Recreational Utility Vehicles) >> Clutch Kit?? 07 660 Rhino (pls help) Page: [1]
Clutch Kit?? 07 660 Rhino (pls help) - 11/10/2008 7:27:06 PM
trevormcfar
I am looking for a little more performance out of my machine... I have a k&n filter, a jet kit but no other aftermarket (performance) items...  I understand that I will lose top end which is ok... Where I ride is lots of hills, rocks & slower riding which is why I am looking at more low end performance rather than top end speed..... Are there brands to stay away from?  Brands to research & look at buying?  I have 26" ITP Terra Cross Tires so not much bigger than stock.... Given my style of riding, any thoughts would be appreciated....
2007 Rhino, 26" Terracross with ITP SS108, Floor Mats, Box Rails, A Arm Protection Front & Back, Warn 3000lbs Winch, Underseat storage.
RE: Clutch Kit?? 07 660 Rhino (pls help) - 11/10/2008 10:27:34 PM
shawnley1222
Get an aftermarket CDI Box it will help ALOT with all around performance
07 660 Camo Rhino
29.5 Swamplites
Goril la 3k Winch
2" Lift
plus alot more goodies with an endless mod list
http://southernsxsriders.forumakers.com/index.htm
(in reply to trevormcfar)
RE: Clutch Kit?? 07 660 Rhino (pls help) - 11/11/2008 7:00:14 AM
neverrideahonda
A cdi isn't gonna help with low end at all. All it does is remove the rev limiter. There really isn't an easy or cheap fix for low end. 4bama1 knows a little washer trick to help low end, but it will take some top end away. Might be something you are interested in.
Chad Broadus
www.undergroundatv.com
Home of Team Tipsy aka "The Party Crowd"
If you don't stand behind our military, maybe you should try standing in front of them.
(in reply to shawnley1222)
RE: Clutch Kit?? 07 660 Rhino (pls help) - 11/11/2008 7:03:42 AM
RAZORKILLER50
Put some 16 gram weights in the primary and probally a blue spring in the secondary since you dont have but 26" tires
BAYOU SNORKELS BOG TEAM HAUGHTON # 50
02 PRAIRIE X
09 RZR X
C . M. R. 2ND OVERALL RUV
SPEED COSTS MONEY HOW FAST YOU WANT TO GO ?
(in reply to neverrideahonda)
RE: Clutch Kit?? 07 660 Rhino (pls help) - 11/11/2008 8:02:24 AM
Boost_it
If you get a CDI that is advancing the timing, especially on the bottom, you will see an improvement.
I would call EPI and see what they recommend for clutching. Normally they change the internal engagement springs and that will help get the motor into a better powerband before the engagement. Their kits will also change the roller weights and secondary spring.
When looking at aftermarket sheaves, be sure they supply the "underdrive" washer as this is more what you are after. Or find someone that knows the "washer trick" mentioned above as a $0.50 washer is a lot cheaper than an aftermarket sheave.
(in reply to RAZORKILLER50)
RE: Clutch Kit?? 07 660 Rhino (pls help) - 11/11/2008 8:54:42 AM
boss500
i bought a rhino 660 with cdi and clutch kit installed. not sure which clutch kit but i'm turning 28" laws no prob
2005 Foreman
27" Mud Lites
2" Custom Snorkle
K&N Air Filter+Precharger
Dynojet
HMF Utility
HL clutch kit
HL 2" Lift
Powermadd hand guards
2000 pound Superwinch
Rear bumper
2006 Yamaha Rhino 660 SE
28" Outlaws
CDI box
Clutch kit
2" HL lift
2" Wheel spacers
K&N Air filter
Custom stereo
3000lb Warn winch
(in reply to Boost_it)
