superbrute
ORIGINAL: matprice yeah that would be it Yeah, everything is tight and clean on the solenoid. The two smaller male connectors are already full of grease on it. I don't know. I guess it's good that this minor issue is all that is wrong with the bike. Oh and my rear gear box seal is leaking but I wouldn't think that would be hard to change. Loosen 13mm bolt at gear box side of shaft, loosen rear diff, slide diff back which will let the driveshaft come out of the gear box. Pop out old seal and install new. Right?
06 Brute Xtreme Racing 853BBK, 4" CATVOS Lift, etc. 08 Canam 800 Outlander, 29.5's on Torks, Full Skids, Center Snorkel, Hmf, Power Commander, HD Front Springs w\ pipe lift, UNI filter, Green primary spring Custom tuning by MaD Powersports
