John316
I have a charging system problem that I am trying to find. I have a 2005 A/C 500 4x4 I am measuring DC voltage at the battery I reach a maximum of 12.8 volts. Lower than specified (According to the manual I have.) When I unplug the connector as described and measure A/C voltage at the connector on the right side of the engine I am placing both the red and black terminals of my meter on one of the 3 wires in the connector. At this point I am able to achieve the specified value of 62 A/C volts at the elevated RPM range. 30 volts at idle....Is this the correct way to test the stator or am I not doing something incorrectly...If I am doing this correctly then the values obtained show that stator is OK. I did attempt to measure from the negative terminal and also the same 3 pin connector and got substanially lower numbers. Resistance test are as follows charging coil 0.9 - 0.7 ohm (spec 0.32-0.48) trigger coil 225 ohm (spec 160-240) source coil 0.2 ohm ( spec 0.08-0.12) little advise anyone GWC?
< Message edited by John316 -- 10/9/2008 11:52:01 PM >
http://www.quadsforchrist.net/index.php **THE ESSENCE OF DESTINY** Watch your thoughts,for they become words. Choose your words, for they become actions. Understand your actions, for they become habits. Study your habits, for they become character. D
