CONFUSSION ON SNORKEL?
All Forums >> [Most Popular Discussions] >> Tech Questions >> CONFUSSION ON SNORKEL? Page: [1]
CONFUSSION ON SNORKEL? - 10/13/2008 1:16:57 PM
JCARP4483
2006 Honda foreman 500 S
I snorkeled my bike satarday and went riding sunday. I rode about 4 hrs going in and out of fairly deep holes but then we were getting ready to leave and i was going to try one more deep hole before we left. And i got dead in the middle. snorkel was not under and i go to hit the gas to pop up the front end and it just went dead. No sputter nothing just dead. There was a guy there who said something about a line that goes from the crankcase into the air box. that his buddy had to snorkel. It was a metal line. I dont know it went dead but not a drop of water in the air box and no water in the carb. I am at a loss for words anyone have any suggestions
2008 Brute Force 750
Stock
2006 Honda Foreman 500 S (Rumble Bee Ed.)
30" Mudzilla's
14" SS112's
HMF Exhaust
Dyno Jet Kit with K&N Filter w/pre wares outer filter
2" Xtreme Lift Kit
HL Spring
2" spacers
Winch Mounted on custom bumper
racks rhino lined
Black Body Plastic and Pod Light Cover
Super Duty Clutch Kit
Turner Cycles U Joint
Gear Reduction
RE: CONFUSSION ON SNORKEL? - 10/13/2008 1:40:30 PM
gordo
water in the crankcase?
You have several secondary lines to water proof besides the airbox,,,, crankcase, carb vent, carb drain, diffs, brakes, etc,,,,,,,
2000 Honda Fourtrax
Warn 424/Warn 2500 Winch
HL Front Disk Brake Kit/Snorkeled
1997 Honda Fourtrax
Warn 424/Viper 2500 Max Winch
1996 Honda Fourtrax
HL Disk Brakes/Warn 424
G o r i l l a XT3000 Winch/Snorkeled
1994 Honda Fourtrax Blue!
Got a winch,,, Nothing Else,,, Yet
1990 Honda Fourtrax
Warn 424/Viper Max 2500 Winch
HL Disk Brakes
PM me for info
(in reply to JCARP4483)
RE: CONFUSSION ON SNORKEL? - 10/13/2008 3:42:01 PM
Cyote
You need to reroute are plug your carb overflow the one way valve did not work. you also need to vent your crankcase, 2 carb vents, rear brake, fan, and both diffs.
RE: CONFUSSION ON SNORKEL? - 10/13/2008 4:35:45 PM
contentsunderpressur
Yea that one way valve on the bottom of the carb is no gaurantee.  They go bad all the time.
03 700 sportsman SOLD
6 in monkey lift
29.5 laws
Progressive spring kit
relocated radiator
snorkeled
1.5 wheel spacers
fender extenders
08 800 sportsman (stealth)
Bone stock for now.
05 Honda Foreman 500
stock with a snorkel
(in reply to Cyote)
RE: CONFUSSION ON SNORKEL? - 10/13/2008 5:16:38 PM
Black Redneck
It almost sounds like something electrical.  Did you grease all your connections?  Seems like it would have been a sputter or something if water had gotten into the engine. JMO
2006 AC 700 EFI
Custom snorks
4 - 27x9x14 Swamp Lites on black SS 108's (trail tires)
4 - 29.5x10x12 Laws on LE wheels (mud tires)
HMF Utility
Optimizer
Outlaw clutch kit
LE Bumpers
Rad Reloc
XPatv 2" lift
Custom Tunes
Eqqis temp and volt gauges
TEAM YO MONEY
"FUN ON YO DIME"
"Keep talkin smack and I'll make ya famous"
(in reply to contentsunderpressur)
RE: CONFUSSION ON SNORKEL? - 10/13/2008 6:44:51 PM
One other possiblity is water getting in through where the throttle cable is hooked.  That plastic cover on the side of the carb will leak sometimes.  Best thing to do is plug off the over flow drain in the bottom of the carb, die electric grease all of your electrical connections including the plug wire and spray the carb really good with plastic spray.
6 in monkey lift
29.5 laws
relocated radiator
snorkeled
1.5 wheel spacers
fender extenders
Bone stock for now.
(in reply to Black Redneck)
RE: CONFUSSION ON SNORKEL? - 10/13/2008 10:25:31 PM
JCARP4483
well i havent done any electrical stuff yet and that is what i was thinking but what electrical would just kill it?
Stock
30" Mudzilla's
14" SS112's
HMF Exhaust
2" Xtreme Lift Kit
HL Spring
2" spacers
racks rhino lined
Gear Reduction
RE: CONFUSSION ON SNORKEL? - 10/14/2008 7:04:00 AM
bansheefan03
the spark plug
2006 rhino 660
98 300
376 bbk,4.5mm stroked crank,ported head,ids2,snorkle,lift,body lift,locker,EDL/ ****s ,axle paddle,459 cam,gear reduction,clutch kit,warn 424,chrome XL2 wheels,katana oil cooler,400ex carb
98 300
not really sure how much lift, ape axles,gear reduction,xl2 wheels, axle paddle,and lots more to come
RE: CONFUSSION ON SNORKEL? - 10/14/2008 7:05:28 AM
bansheefan03
the spark plug
2006 rhino 660
98 300
98 300
RE: CONFUSSION ON SNORKEL? - 10/14/2008 7:37:15 AM
Yep spark plug
6 in monkey lift
29.5 laws
relocated radiator
snorkeled
1.5 wheel spacers
fender extenders
Bone stock for now.
(in reply to bansheefan03)
RE: CONFUSSION ON SNORKEL? - 10/14/2008 7:38:45 AM
If the water gets in the boot to the tip of the spark plug it'll die just like you turned the key off.  Take the boot off and fill it up with die electric grease.
6 in monkey lift
29.5 laws
relocated radiator
snorkeled
1.5 wheel spacers
fender extenders
Bone stock for now.
RE: CONFUSSION ON SNORKEL? - 10/14/2008 2:29:35 PM
01RUBMUDDER
I agree with contentsunderpressur i've had the same thing happen to me before, after it happened coated everything in electric grease and it hasn't died since.
RE: CONFUSSION ON SNORKEL? - 10/14/2008 3:08:56 PM
greenswampredneck
water def. seeped in the crankcase. the same thing would happen to my foreman every now and then. i siliconed that sucker up and she quit. the foreman's def. arent hondas best water bikes
(in reply to 01RUBMUDDER)
RE: CONFUSSION ON SNORKEL? - 10/14/2008 9:23:59 PM
JCARP4483
how do you assume water seeped into the crankcase. the oil was brand new and still looks brand new
Stock
30" Mudzilla's
14" SS112's
HMF Exhaust
2" Xtreme Lift Kit
HL Spring
2" spacers
racks rhino lined
Gear Reduction
(in reply to greenswampredneck)
RE: CONFUSSION ON SNORKEL? - 10/14/2008 9:29:22 PM
If water got into the crankcase you would see it in your oil.  I don't think that's your problem.
6 in monkey lift
29.5 laws
relocated radiator
snorkeled
1.5 wheel spacers
fender extenders
Bone stock for now.
RE: CONFUSSION ON SNORKEL? - 10/15/2008 5:38:20 PM
JCARP4483
i know its not no water got into the motor. I am thinking spark plug. So you just pack the grease in the Spark plug sleeve thing?
Stock
30" Mudzilla's
14" SS112's
HMF Exhaust
2" Xtreme Lift Kit
HL Spring
2" spacers
racks rhino lined
Gear Reduction
RE: CONFUSSION ON SNORKEL? - 10/15/2008 7:56:48 PM
Yea, just unplug it from the spark plug and fill it up with die electric grease.  It wouldn't be a bad idea to do all of your electrical plug ins and spray the carb down with plastic spray.
6 in monkey lift
29.5 laws
relocated radiator
snorkeled
1.5 wheel spacers
fender extenders
Bone stock for now.
RE: CONFUSSION ON SNORKEL? - 10/16/2008 10:41:07 AM
JCARP4483
ok thanks
Stock
30" Mudzilla's
14" SS112's
HMF Exhaust
2" Xtreme Lift Kit
HL Spring
2" spacers
racks rhino lined
Gear Reduction
RE: CONFUSSION ON SNORKEL? - 10/16/2008 12:44:15 PM
Good luck.  I know how aggrivating these problems can be.
6 in monkey lift
29.5 laws
relocated radiator
snorkeled
1.5 wheel spacers
fender extenders
Bone stock for now.
RE: CONFUSSION ON SNORKEL? - 10/16/2008 1:01:24 PM
BNYCE
ORIGINAL: bansheefan03
the spark plug
Exactly, you need to scilicone the boot wire for the plug and dielectic grease the plug, ifyou dont have water in the box or milky oil, that is what is wrong
09 DU grizz 700eps fi
stuff to make it better
RIP 08 bf 750 Metallic Blue, stuff on it
The Wifes
08 BF750 Team Green
PINK SNORKELS
PINK RIMS
PINK AMO CANS
other stuff too
Deep and Dirty ATV Spring TX
Chip Chip
0.859
