CARB SLIDE MOD
CARB SLIDE MOD
All Forums >> [OEM Discussions] >> Suzuki >> CARB SLIDE MOD Page: [1]
CARB SLIDE MOD - 8/28/2008 10:24:57 PM
KING VINNY
WHAT IS A CARB SLIDE MOD????
RE: CARB SLIDE MOD - 8/28/2008 10:27:38 PM
You slide the carb out and you slide a fuel injector in Ha Ha
Just kidden
2006 Suzuki 700
8" SLC Lift
Turner drive line
VDI
Dalton clutch
http://www.youtube.com/watch?v=xkkWaMsILQU
http://www.youtube.com/watch?v=Cz4fK9eU904
http://www.youtube.com/watch?v=DNMW8PgIm5E
(in reply to KING VINNY)
RE: CARB SLIDE MOD - 8/28/2008 10:39:37 PM
KING VINNY
HA HA I WISH. NO REALLY WHAT IS IT?
(in reply to #4)
RE: CARB SLIDE MOD - 8/28/2008 10:42:51 PM
Sweet_Tooth
Here it is.
http://www.highlifter.com/forum/m_2147681/mpage_1/key_slide%2cmod/tm.htm#2176661
Real name: Lucas
Fact: God hates fanboys!!
2003 Honda Rancher 4x4 ES "SOLD!"
I'll miss ya little buddy "sniff"
2007 Suzuki Vinson Manual
UNI Filter
Warn Bumper
Round Foglamps
Rear work light
Viper MAX 3000lb winch
Maxxis 4x4 wheels with 27" Dirt Devil II tires
10's front
12's rear
RE: CARB SLIDE MOD - 8/28/2008 10:55:39 PM
KING VINNY
COOL THANKS. BUT WHAT EXACTLY DOES IT DO?
(in reply to Sweet_Tooth)
RE: CARB SLIDE MOD - 8/28/2008 10:58:22 PM
Sweet_Tooth
Dunno. But looks like it gives the Vinson and Eiger more power.
Real name: Lucas
UNI Filter
Warn Bumper
Round Foglamps
Rear work light
10's front
12's rear
RE: CARB SLIDE MOD - 8/28/2008 11:00:28 PM
KING VINNY
COOL. HAVE YOU DONE IT TO YOURS?
RE: CARB SLIDE MOD - 8/29/2008 8:26:43 AM
Sweet_Tooth
Nope. I have extended Warranty on mine and I ain't touching it til it ends. Only thing I do is fluid changes.
Real name: Lucas
UNI Filter
Warn Bumper
Round Foglamps
Rear work light
10's front
12's rear
RE: CARB SLIDE MOD - 8/29/2008 8:51:39 AM
MudKing02
I did it. You need a bigger pilot jet for it to be effective.
07 Vinson Manual 2" HL lift, Gators on Douglas Rattlesnakes, snorkel, jets, K&N, Warn RT 2500, carb slide mod
RE: CARB SLIDE MOD - 8/29/2008 1:08:51 PM
The "slide mod" on the carb should not require any jetting. All it does is allow the slide to open faster thus giving it better throttle responce, it will make it have more "snap" off the line.
It does not increase HP either just increases throttle responce. I have also been clipping about 4 coils off the vacuum slide spring to help alittle more with the responce and it does work well. this is a Free mod that is worth the time to do.
I have done this to allmost a dozen quads and not one problem from it.
< Message edited by GWC -- 8/29/2008 2:15:30 PM >
08 650H1 LE
Warn 3.0
Snorkeled,Rad relocated
Custom mounted gauges
muffler tweaked
Custom clutch kit, 4.0 gears
"G" axles
29.5 Laws on custom LE wheels
30" MLs on Black Castle Roks
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
26" 589MTs on ITP type 6s
Hard.Pack.Arctic.Cat
(in reply to MudKing02)
RE: CARB SLIDE MOD - 8/29/2008 1:11:02 PM
MudKing02
I was speaking from personal experience GWC. When I did it I really didnt notice any extra jump off the line. Maybe I'm messed up somewhere, but I dont think so. Also, are you clipping the DJ spring or the stock spring?
(in reply to GWC)
RE: CARB SLIDE MOD - 8/29/2008 1:25:12 PM
the stock spring,  DJ does not send a new spring in the AC kits  guess they think it does not need it..? just like there kits dont come with big enough jets if your snorkeled and have a aftermarket muffler..
shoot on the 500 kit they did not not even tell me to drill the slide out but the 650 kit they do..lol its the same carb so they both should need it, well i think anyway..lol ]
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
RE: CARB SLIDE MOD - 8/29/2008 2:59:44 PM
MudKing02
The needle and the spring were just about the only things I could use out of my kit. I'm on the 128 jet right now which is the biggest jet that comes in the kit. If I'd have went with 2" snorkel the kit wouldnt have helped me at all.
(in reply to GWC)
RE: CARB SLIDE MOD - 8/29/2008 3:05:16 PM
the AC kit goes up to a 146 so if a guy wants bigger jets for his Vinson then they would be better off buying the AC kit , it is the same carb correct 36mm Kehin ..??
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
RE: CARB SLIDE MOD - 8/29/2008 3:15:50 PM
MudKing02
yea, I believe they're the same carb. Not 100% though.
(in reply to GWC)
RE: CARB SLIDE MOD - 9/1/2008 1:26:45 PM
TeamMudd
i went with stock brand (keihin) jets.  got more jets and cheaper than the DJ kits.  i just used washers to "shim" the needle instead of having an adjustable one with a cute little C-clip.
i can't tell you if the slide mod worked or now, lol, i did a pipe / jet / filter / slide mod all at one time.  i read on here than the only time a new pilot jet is needed is when you install an after market filter and snorkel.
Jason
Team Mudd Racing Pres.
WWW.TEAM-MUDD-RACING.COM
MINE: '07 Vinson *29.5 Laws/28 mudlites *"TEAM MUDD" snorkel (my design)*Lift kit*18% Gear reduction*reverse lights*aux head lights*Moose cargo seat*EPI clutch kit*HMF*UNI filter*Jetted
HERS: '07 Vinson *26 XTR's *"TEAM MUDD" snorkel*reverse lights*custom seat back*UNI filter
RE: CARB SLIDE MOD - 9/1/2008 4:47:42 PM
MudKing02
Well by God I need one. LOL I need you HMF too. Your wife called me and told me it was too loud.
(in reply to TeamMudd)
RE: CARB SLIDE MOD - 9/1/2008 5:41:21 PM
the DJ kits cost more then just buying new jets but that needle you get is FAR better then your stock needle jet.
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
RE: CARB SLIDE MOD - 9/1/2008 5:57:59 PM
TeamMudd
i think you can order JUST the needle from them for about $20 (someone will correct me on that one)!!  i've heard they are actually shorter than the stock needles as well, is that true??
Jason
(in reply to GWC)
RE: CARB SLIDE MOD - 9/1/2008 6:59:16 PM
MudKing02
I dont think they're any shorter, but the flow characteristics are much better with the DJ needle. It's more finely tappered.
Mudd I was just kiddin about the wife thing. No offense was intended.
RE: CARB SLIDE MOD - 9/1/2008 7:13:29 PM
TeamMudd
heck you ain't lyin, lol  she already said she ain't following me NO WHERE!!
belive it or not i bought a quiet core $18 at a local shop, put it in, fired it up.........YANKED that $18 piece of crap stainless steal baffel right the helz out.........it sounded like CRAP, every one on here that warned me about it, i'll be the first to admit YOU WERE RIGHT!!!  wide open its REALLYYY REALLLLYYY loud when you gas on it, sounds great at idle (i think) even the wife thinks it's ok........gap it open and she cringes almost as bad as i do, lol!!
i guess till i find me an LRD i'm gonna run it wide open.........fellow riders beware, lol!!  all my friends have said i get to bring up the tail end, cuz no one wants to ride behind me, hahaha!
hhhmmm more tapper huh, we have a lathe at work, haha
Jason
RE: CARB SLIDE MOD - 9/1/2008 7:33:57 PM
MudKing02
Let me know when you find that LRD and I'll take the hmf off your hands. Anything to make your wife happy you know. All seriousness now, I dont really think the HMF's are that loud, I was riding with a AC 500 with an HMF and I didnt think it was that bad.
Post #: 22
RE: CARB SLIDE MOD - 9/1/2008 7:49:10 PM
Wait untill you take it for a dip it in water a few times then it gets loud
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
Post #: 23
RE: CARB SLIDE MOD - 9/2/2008 12:24:59 PM
MudKing02
It wasnt new by any means G.
(in reply to GWC)
Post #: 24
RE: CARB SLIDE MOD - 9/2/2008 1:32:36 PM
oh i see, then its allready crazy loud
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
Post #: 25
1.203
