CARB ??????? PLEASE REPLY
All Forums >> [OEM Discussions] >> Arctic Cat >> CARB ??????? PLEASE REPLY Page: [1]
CARB ??????? PLEASE REPLY - 10/1/2008 8:14:22 PM
JROCK500
OK GUYS I GOT A ? AND I KNOW SOMEONE KNOWS THE ANSWER! OK TODAY I WENT RIDING AND WE WERE INSOME DEEP WATER ( UP TO THE HANDLE BARS ) AND I GOT WATER IN MY CARB AND CUT OFF IN THE WATER HOW DID THIS HAPPEN ? I HAVE A 2007 ARTIC CAT 500 4X4 IT IS SNORKLED, NO WATER  IN THE INTAKE AT ALL I CHECKED NO WATER IN OIL! JUST WATER GOT IN THE CARD BOWL. IT HAS NO VENTS ON IT NO WERE THAT I CAN FIND AND NO OVER FLOW THAT I CAN FIND THE ONLY THING IT HAS IS A SCREW TO DRAIN THE BOWL I DRAIN THE WATER AND IT FIRED RIGHT BACK UP HOW DID THIS HAPPEN AND HOW DO I KEEP IT FROM HAPPNEN AGAIN? OTHER THAT STAYING OUT OF DEEP WATER
2007 ARTIC CAT 500 AUTO ,HMF EXHAUST,K&N FILTER,DYNO JET JET KIT,EPI CLUTCH KIT, 27" S-BACKS ON ITP SS 106 RIMS, SNORKLED,RAD RELOCATED. MY LUG NUGS REQUIRE MORE TORK THAN YOUR ATV MAKES!
RE: CARB ??????? PLEASE REPLY - 10/1/2008 8:16:17 PM
the float bowl drain is a vent as well, you will need to plug it off or put a one way check valve on it. happens all the time if its not plugged off.
08 650H1 LE
Warn 3.0
Snorkeled,Rad relocated
Custom mounted gauges
muffler tweaked
Custom clutch kit, 4.0 gears
HL springs, HL spacers
"G" axles
29.5 Laws on custom LE wheels
30" MLs on Black Castle Roks
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
26" 589MTs on ITP type 6s
Hard.Pack.Arctic.Cat
(in reply to JROCK500)
RE: CARB ??????? PLEASE REPLY - 10/1/2008 8:24:09 PM
JROCK500
SO YOU SAYING WERE I TURNED THE SCREW TO DRAIN THE WATER I NEED TO ADD A FUEL LINE THAT IS ABOVE MY WATER RIDING LEVEL CORRECT
(in reply to GWC)
RE: CARB ??????? PLEASE REPLY - 10/1/2008 8:32:12 PM
yeap  that it, water is going back up that tube once the pressure get to be to much and flooding the motor out.
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
RE: CARB ??????? PLEASE REPLY - 10/1/2008 8:36:24 PM
JROCK500
OK THANKS GWC I HEAR ALOT OF GOOD STUFF ABOUT YOU 2 MORE ? 1 WERE CAN I FIND THIS ONE WAY CHECK VALVE AND 2 CAN YOU LEAD ME IN THE DIRECTION OF SOME GOOD MODS FOR MY BIKE
(in reply to GWC)
RE: CARB ??????? PLEASE REPLY - 10/1/2008 8:39:56 PM
bustedknuckles
We have had bad luck with those check valves. They get mud in them and hang open. Just plug it off. Make sure you are able to unplug it so you can drain your carb if necessary.
click here and buy my suburban
"APE AXLE"
STEELHORSES
CATVOS
08 ThunderCat
08 650H1
RE: CARB ??????? PLEASE REPLY - 10/1/2008 8:40:41 PM
i think a local auto parts store might have them, i know my old Polaris had one on it so they sell them as well.
Looks like you got about most everything on there allready. add a Web cam and some 4.0 gears is about allyou got left unless you do a Big bore kit.
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
RE: CARB ??????? PLEASE REPLY - 10/1/2008 8:43:01 PM
big tony
NITROUS, turbo, ....forgetting all the good stuff lol
08 650 H1 CAMO
07 650 H1 2-Tone...lol
98 454 Bearcat 2x4
90 Kawasaki Bayou 300
84 Suzuki 185
Steel Horses
Catvos
Steve's ATV
(in reply to GWC)
RE: CARB ??????? PLEASE REPLY - 10/1/2008 8:50:27 PM
Yeah turbo that would fix it right up about 15lbs of boost and you would be good to go
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
(in reply to big tony)
RE: CARB ??????? PLEASE REPLY - 10/1/2008 8:53:52 PM
JROCK500
WELL I THOUGHT I HAD DONE ALL I NEEDED TO RIDE IN WATER BUT GUESS I FORGOT SOMETHING DUHHH! I DID TAKE AND RUN MY FRONT AND REAR DIFF VENTS UNDER THE SEAT AND INSTALL INLINE FUEL FILTERS ON THEM WITH THE LITTLE ACORDING LOOKING THING ON THE OTHER END OF THE FILTER , FIGURED IF I DID GET WATER IN THERE I DID ATLEAST WANT IN TO BE CLEAN ALSO DID THE SAME TO THE FUEL TANK VENT THANKS GUYS FOR ALL THE INPUT IF THERE IS SOMETHING IM MISSING FOR WATER RIDING PLEASE SHARE THE INFO!
RE: CARB ??????? PLEASE REPLY - 10/1/2008 11:32:56 PM
1badkittykat
ORIGINAL: bustedknuckles
woops... i monkey glued mine on lmao
07 Kitty Kat 650 H1
28'X9.5' LAWS, Black Magic Exhaust, Full Snorks, Aluminum Products Skids, Jams w/ ipod n Otter Box, Strobes, Death Grips, Jetted, LE Wheels & Bumpers, Oddysee PC-680 Battery, AC Backrest
http://www.myspace.com/itsajeepthing699
http://youtube.com/user/maddmatt469
Matt
(in reply to bustedknuckles)
RE: CARB ??????? PLEASE REPLY - 10/2/2008 6:52:42 AM
P360onBugs
im sure ppl here know it but you ahve to be more mindfull if you plug the carb drain off.  that hose serve 2 purposes. 1. carb drain and 2. overflow drain.  if you float sticks and it is pluged off it will fill the crank with gas and wash out the rings.
just make sure you do not get your carb VENT line(line at the top of the carb) pinched are clogged. it will stick the float in a hurry.
good luck with the cat.
Plaase dont tell the yammi guys but i miss my 500m at lot these days.
< Message edited by P360onBugs -- 10/2/2008 6:56:53 AM >
MUD BIKE=Blue 08' Big Bear 400i
motor mods and mud mods.
TRAIL BIKE= GREEN 08 Brute Force 650i
Of course my winches work--THEY'RE WARNS aint they?
(in reply to 1badkittykat)
RE: CARB ??????? PLEASE REPLY - 10/2/2008 8:03:21 AM
LOL yeah they all have there goods and bads about them.
but hes right if your float bowl drain/vent is pugged off and it sticks for some reason it will flood the motor with gas, that why i tel people to plug it OR get a one way check valve, BUT like Bustedknuckles said the one way can get mud in it and stick.
mine is plugged off either way it could be a pain in the butt..lol
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
(in reply to P360onBugs)
RE: CARB ??????? PLEASE REPLY - 10/2/2008 8:30:14 AM
bustedknuckles
I've seen some of them load up with it plugged, but it was a bad off camber hole. Not sure what a perfect fix is for this. I'm scared of the check valves. Seen a few fail. I'd rather my bike load up, than get muddy water in the carb.
"APE AXLE"
STEELHORSES
CATVOS
08 ThunderCat
08 650H1
(in reply to GWC)
RE: CARB ??????? PLEASE REPLY - 10/2/2008 8:33:17 AM
yeap muddy water in the carb sucks....
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
RE: CARB ??????? PLEASE REPLY - 10/2/2008 8:41:01 AM
JROCK500
HOW ABOUT IF I CAME OF THE VENT WITH FUEL LINE THEN PUT IN A INLINE FUEL FILTER WITH A CHECK VALVE ON THE END IF IT DOES EVER STICK OPEN IT WANT BE FILLED WITH MUDDY WATER GOOD IDEA OR NO?
(in reply to GWC)
RE: CARB ??????? PLEASE REPLY - 10/2/2008 8:56:59 AM
bustedknuckles
Maybe if you put the check valve between the filter and the carb, it would keep the mud out of the check valve.
"APE AXLE"
STEELHORSES
CATVOS
08 ThunderCat
08 650H1
RE: CARB ??????? PLEASE REPLY - 10/2/2008 1:50:22 PM
JROCK500
OK I GOT THE KITTY ALL FIXED UP NOW I INSTALLED A FUEL  LINE COMING OFF THE CARB VENT/DRAIN THEN I INSTALLED A CHECK VALVE AFTER THAT A SHORT PIECE OF FUEL LINE WITH A BRASS 4 WAY COUPLIN WITH 3 VENT COMING OFF OF IT ONE TO THE RIGHT SIDE ONE IN THE MIDDLE AND ONE ON THE LEFT THIS SHOULD WORK! IF THEY ALL GET PLUGGED AT ONCE IT WAS MENT TO HAPPEN IN MY BOOK! OH ALSO TRIED IT OUT AND IT WORKED LIKE A CHAMP THANKS GUYS
RE: CARB ??????? PLEASE REPLY - 10/2/2008 7:32:49 PM
oilfieldbeggar
that got way to confusing towards the end! I just stuck a screw in mine. Works!!
2" sneak snorkle,
Djet w/h 148 and 42
all the free mods listed so far
sweedwerx pipe
"Puck-lift installed"
Dynatek, drilled rollers
Da Purple springs installed!!
29.5 S/Lites on Type 7's
clip on 3, 4 curls on spring
0.813
