mudracer80
They are both Hot cams your regular Hot Cam is a stage 1 and it is for mid to top end power and the mudbuster is for low end. Unless your geting a heck of a deal on them then I would do what Bad brute 650 suggested.... The Web 150I is a drop in Cam like hotcams and doesnt require any springs and will make more power then the Hot Cams. If you puting High comp pistons in I would suggest geting Cams and springs from one of the several Custom Kawi builders..... it is a night and day diffrence from a drop in cam.
06 Arctic Cat 665 V-TWIN 11.5:1 CWR450 cams Swx full exhaust, dynatek 2" lift, ape'ed, lawed jeted and clutched Wifes Bike 07 Grizzly 660, 5.5" Ape lift, clutch kit, custom snorkel, 30" Mudzillas, Rad Relocated Hard Pack Arctic Cats It all seems HardPack when you ride a CAT STEEL HORSES
