mudcrazee
ORIGINAL: mudcrazee Lets get all the resets in one post. If you have a BF650, BF650i, Prarie 360-700, lets post the resets to help everyone out. Here is the one for the 750, I'll try to find the rest if noone else posts. To reset, turn ignition off and pull cvt cover. Put switch inside cover back into "on" postion. Remove seat and disconnect the 2 connectors grey and black and reverse them. They are located if sitting on quad in right rear corner. The grey one is not connected to anything, it's just a reset plug. Grey into black and black into grey. On top of the CVT cover is a black connector that goes to the switch inside the cover, disconnect that at this time. With the 2 still reversed and the black one disconnected, turn the key to the on, but don't start the quad. Observe the belt light. When it stops flashing really fast and starts flashing slow, the belt light is reset. Turn key off, and put the 2 connectors under the seat back to their original connectors and plug the connector switch for the CVT back in. Your done. If it's just the 100 hour causing the light to flash, you do not have to remove the CVT cover and flip the switch. Just swap the plugs and follow the rest of the procedure mentioned above.
2005 Camo BF 750, SSATV 2" lift, JE Pistons, HL Rack Radiator, 29.5's on ITP 5's, BS, 2" Exhaust Snorkel, Dyna CDI, HL Module, HL Extreme Clutch, HL Diamond Bumper and Bash. BFWDP 2007 EE Rhino660 28" Outlaws on Castlerocks, Stereo system, EBC Brakes. http://community.webshots.com/user/mudcrazee http://www.southernswampboyz.com
