Base tune your EFI without a wide band
All Forums >> [OEM Discussions] >> Can-Am BRP >> Base tune your EFI without a wide band Page: [1]
Base tune your EFI without a wide band - 5/28/2008 3:09:48 PM
JohnCannon
For those who have snorkels and live in areas of the world that do not have any way of reading your A/F numbers here is a way you can tune your EFI out.
This only works for the Power Commanders. The Optimizers are crap and will not let you tune small areas of your EFI map.
EFIs and carbs tune out very differently but some of the tuning methoods for carbs can be adapted for EFIs. A carb can be tuned by reading your plugs in 3 different areas. Idle, half throttle, and wide open throttle. If you install clean plugs into the motor you can let sit at idle for a couple of minutes, pull the plug out and read the plugs color for a lean or rich A/F condition. You can do this same methood for part and WOT.
EFIs can be rough tuned in using the same methood.
1) Start by installing a clean plug in just the rear cylinder. (There is no need to install a new plug in the front because both cylinders use the same map unless you advance the map)
2) crank the motor and let run for 5 minutes at idle. Read the rear plug.
3) connect to the PC3 with your computer.
4) If the plug looked dark subtract 5 from current map values in the 0%,2%,5%,and 10% throttle positions from 1250rpm to 8000. (most of these RPMS will not be used but to be simple you can edit all the values in these ranges)
5) On average adding or subtracting 5 points from the map will effect your A/F by 1/2 point. So if you was at 13/1 A/F and subtracted 5 you would be at 13.5/1 A/F. During a base tune I would only use multiples of 5 when adding or subtracting. You will nto be able to tell a difference subtracting or adding lower then 5.
6) Plug check your idle again until the plug has a slight tan color.
7) Next do your WOT the same way you did your idle only this time you will only be editing the 100 column on the map. A few long WOT runs should be good enough to get you a reading
8) after the WOT tune is done you can do the other throttle positions by screwing in the throttle stop screw in so that the "%Throttle" field on the PC3 does not go past the throttle position you are tuning.
This is one step closer to fine tuning your EFI.
You can find more how-to articles and videos on MUDandDIRT.com.
Enjoy
< Message edited by JohnCannon -- 5/29/2008 6:32:29 AM >
MaD MOTORSPORTS
.: www.MUDandDIRT.com :.
YouTube:. http://www.youtube.com/mudanddirt
MaD MOTORSPORTS CUSTOM EFI TUNING
07 Competition Sports/MaD Outlander X
PROUND SPONSOR OF
Team Gander Mtn
Bama Boggers
Matt Thompson
Brutewise
I support the troops 100%. You guys are my heros..
RE: Base tune your EFI without a wide band - 5/28/2008 3:34:18 PM
KrisF
You're the man!
2008 Can Am Renegade 800 "X"
No longer a virgin...
-Ron Woods Full Exhaust
-Uni Air Filter
-Dalton Clutch Kit
-PCIII
-Home Grown Snorkels
-12X7 MSA Nukes
-28" Monkeybacks
(in reply to JohnCannon)
RE: Base tune your EFI without a wide band - 5/28/2008 4:11:57 PM
Dirt2race
Perfect explanation John, you have a way of explaining things and making it seem so simple. Thanks for all you do to make all of us a little faster. I purchased the optimizer when I first built this bike and have been happy with it, but I do plan on changing to a PC at one point.
2007 Renegade 800
1004 MRRPM Big Bore Kit
2" pipe lift, PCIII, custom head pipe, HMF, full snorkels, relocated radiator, 29.5 laws, Crush Locks, Comet clutch
2006 Foreman 500 w/ 2" lift, 28" Zillas, HMF pipe
2006 Foremann 500, 26" Mudlites, winch, HMF pipe
2000 Rancher 350, just like they built it
RE: Base tune your EFI without a wide band - 5/28/2008 5:31:31 PM
kscowboy
Great tip John.
TEAM GOR!LLA
POWERED BY CAN AM
#44 REGAN
08 800 outlander max xt
www.myspace.com/kscowboy13
(in reply to Dirt2race)
RE: Base tune your EFI without a wide band - 5/28/2008 7:02:35 PM
engie
added to the helpful links sticky!
Great info!  The way you presented the a/f change is a new and much easier method of thinking for me!   I had always done exact math.  What I mean is, "turning the map up 10 points means your adding 10% more fuel, so if your at 14:1 a/f, you will be 10% richer, thus 12.6:1 would be the new ratio."
I would also like to know more on the method of adding a consistent(say plus 5) value to multiple cells at once.  I was unaware of the possibiliity in the dynojet software until I saw Martymoe do it.  He's from PRC forum, and THE guy to talk to about understanding ATV EFI.  He consistently blew my mind with his knowledge, and it isn't VERY easy to do.  He runs his RZR on closed-loop using a pc3 and wideband commander, along with some custom software he built...
Building a motor or two with a few other little projects...
Victory is not achieved on raceday. It is achieved in the preparation leading up to it.
(in reply to kscowboy)
RE: Base tune your EFI without a wide band - 5/28/2008 9:08:02 PM
biggbowls
Closed loop......hhhhmmmmmmmmm
'07 MAXIMUM 650
For the last time, no racial comments allowed!
< Message edited by mud_dog450 -- 9/22/2008 6:49:15 PM >
(in reply to engie)
RE: Base tune your EFI without a wide band - 5/28/2008 10:58:38 PM
JohnCannon
We getting in deep now!!!!
MaD MOTORSPORTS
PROUND SPONSOR OF
Team Gander Mtn
Bama Boggers
Matt Thompson
Brutewise
(in reply to biggbowls)
RE: Base tune your EFI without a wide band - 5/29/2008 12:31:35 AM
camlaw
you said,john to let it idle for 5 min. then do the wot, the same. do you mean , keep it at wot, for 5 minutes ?
RE: Base tune your EFI without a wide band - 5/29/2008 6:31:44 AM
JohnCannon
No. Making a couple of long WOT runs back to back should give you pretty good reading. Sorry
MaD MOTORSPORTS
PROUND SPONSOR OF
Team Gander Mtn
Bama Boggers
Matt Thompson
Brutewise
(in reply to camlaw)
RE: Base tune your EFI without a wide band - 5/29/2008 8:17:08 AM
MONSTERQUADMANIAC
Great Post John. This should get me by until I am able to get over to Mobile for a Race Tune.
2008 Renegade 800 "X" Edition
R.I.P. Justin Danner Price
04/03/81 - 11/17/2008
RE: Base tune your EFI without a wide band - 5/29/2008 9:28:23 AM
bobhoffmann
does anyone know if a pc3 for the can an 800 can be used on the 650 outlander since they don't sell one specifically for that model? thanks
(in reply to MONSTERQUADMANIAC)
RE: Base tune your EFI without a wide band - 5/29/2008 11:18:24 AM
JohnCannon
Yes but the tune will be way off.
MaD MOTORSPORTS
PROUND SPONSOR OF
Team Gander Mtn
Bama Boggers
Matt Thompson
Brutewise
(in reply to bobhoffmann)
RE: Base tune your EFI without a wide band - 5/29/2008 12:17:24 PM
biggbowls
Got one on mine......was told it had a 650 map but turns out it had the 800 map.......changed maps and has more snap.....waiting for the tuning.
'07 MAXIMUM 650
RE: Base tune your EFI without a wide band - 5/29/2008 1:23:34 PM
bobhoffmann
where were you able to find a map for the 650? and was it for stock or running a certain pipe and filter? I'd go that route until I can get it to a dyno and tune it. I also have a wideband  02 sensor that I can use to see how far off the a/f readings are thanks
RE: Base tune your EFI without a wide band - 5/29/2008 3:32:23 PM
bobhoffmann
went to power commanders website and see that they now have a map for the 650. didn't a couple of months ago
RE: Base tune your EFI without a wide band - 5/29/2008 4:42:07 PM
kleinwild
Great tips but i would much rather pay you!
TBC: Nuff said
08 CATVOS Custom RZR
05 RPM/AMR Prairie
AMRacing ..... when being second is not an option, AMR is the only option
http://www.flickr.com/photos/21905386@N08/
RE: Base tune your EFI without a wide band - 5/29/2008 8:41:24 PM
cleonard
ORIGINAL: bobhoffmann
i think they make a 650 specific one now.
-COLE-
'08 650 H1
murdered out
4" CATVOS lift
30" silverone's
4.0s
custom snorkels by,
STEEL HORSES
1.406
