BB rear hub nut removel
All Forums >> [Most Popular Discussions] >> Tech Questions >> BB rear hub nut removel Page: [1]
BB rear hub nut removel - 9/23/2008 7:20:14 PM
rockinred
hello,can some body give some advice on how to remove the nut on the end of the rear hub?it is the one with the sleve of the nut punched int the grove of the stud.thanks
brandon hollis camo 08 big bear 2"xtreme lift, 26 mud gear,uni filter,HL clutch kit,2500 winch,1" wheel spacers on frount.some more mod soon!
RE: BB rear hub nut removel - 9/23/2008 7:22:48 PM
bansheefan03
just use a impact it will take it off without messing with the bent down tab
2006 rhino 660
98 300
376 bbk,4.5mm stroked crank,ported head,ids2,snorkle,lift,body lift,locker,EDL/ ****s ,axle paddle,459 cam,gear reduction,clutch kit,warn 424,chrome XL2 wheels,katana oil cooler,400ex carb
98 300
not really sure how much lift, ape axles,gear reduction,xl2 wheels, axle paddle,and lots more to come
(in reply to rockinred)
RE: BB rear hub nut removel - 9/23/2008 8:06:23 PM
Jake450s
It's vibration proof that way, not wrench proof.  Twist it like you mean it, it'll come off.  Odds are, when re-torqued to spec, it'll come up to just a shade different location and can be re-staked.  If there's a couple of stakes in a row so you get a big, weak, torn up spot, it's time for a new nut.  You're not supposed to reuse that type of nut.  You should have a new one and not worry about what happens to the stake.  But only the staking ring is compromised, the threads are just fine so long as they're not over or under tightened.  I torque them down and see what I've got to work with before I get new ones.  If the lock ring lines up to a new spot, (they usually do at least once) then you're golden.  Even if you could "unstake" the ring prior to removal, they crack and don't "restake" anyhow so nothing's lost by tearing out that one little spot..
(in reply to bansheefan03)
RE: BB rear hub nut removel - 9/23/2008 8:14:53 PM
kidsoncoffee
What jake said.  And if you can't get it off with an impact gun, take a cutting torch and cut that tab, making sure not to cut into the threads on the end of the cv shaft.  That's what I had to do and I was using an 1100 lb 3/4" MAC impact gun.  That sucker didn't want to come off.
2008 Big Bear 400 4x4
Extreme Products 2" Lift
Custom 2" Snorkel
27" MudZillas
2 Front Apes
DynoJet Jet Kit
UNI Filter
55W Halogen on the Back
More to come......
1999 Yamaha Kodiak 400 4x4
2" Home made bracket lift
1.5" Snorkel
DynoJet Kit
UNI Filter
27" Swamplites on 14" ITPs
(in reply to Jake450s)
RE: BB rear hub nut removel - 9/23/2008 8:53:31 PM
bansheefan03
i think ur mac impact is wore out then cause i have takin a at least a dozen off with my 1/2 inch impact no problem course i keep my air compresser set at 160psi also though
2006 rhino 660
98 300
98 300
(in reply to kidsoncoffee)
RE: BB rear hub nut removel - 9/23/2008 9:37:05 PM
kidsoncoffee
Mine was stuck like chuck.  The impact is fine.  The thing's only a few months old.  And it better not be crappin out as much as I paid for it.  My compressor stays at about 130.  I even had to put heat to the nut after I cut the tab out.  Maybe the smart guys at yammer hammer cross threaded the thing or something.  I need a bigger compressor anyways.  I think you just gave me a reason to upgrade.
Custom 2" Snorkel
27" MudZillas
2 Front Apes
DynoJet Jet Kit
UNI Filter
More to come......
1.5" Snorkel
DynoJet Kit
UNI Filter
RE: BB rear hub nut removel - 9/23/2008 9:41:14 PM
bansheefan03
do u run the impact on half inch air hose or the 3/8 ones on most compressers
2006 rhino 660
98 300
98 300
RE: BB rear hub nut removel - 9/23/2008 9:47:50 PM
kidsoncoffee
It's on 1/2" hose on my craftsman compressor.  We have a smaller kobalt compressor with the 3/8" hose for the die grinders and air ratchet and other stuff.
Custom 2" Snorkel
27" MudZillas
2 Front Apes
DynoJet Jet Kit
UNI Filter
More to come......
1.5" Snorkel
DynoJet Kit
UNI Filter
RE: BB rear hub nut removel - 9/24/2008 11:31:01 AM
BIG BEAR 08
just use a really big 4-way bar or a breaker bar with a pipe on it. what we did to reuse the nut is tighten it up to specs, then drill a hole through the axle and nut then put in a cotterpin. we did this after we replaced the wheel bearing so it didnt go again.
< Message edited by BIG BEAR 08 -- 9/24/2008 11:33:15 AM >
2008 big bear: 2500lb warn winch, now riding on 27" ZILLA's on black 12" SS108's 2005 prarie 360: 26" mudlights, comet clutch, busted
front diff, finally got it moving again on april 17th
85 yamaha tri-moto 200: LONG GONE, but not forgotten
Quote from J_Fred
"I don't get stuck, I just lose traction and stop moving".
RE: BB rear hub nut removel - 9/24/2008 5:28:13 PM
rockinred
i just got it loose,a pull handle ,cheater pipe,and some elbow grease.thanks for all the info
(in reply to BIG BEAR 08)
RE: BB rear hub nut removel - 9/24/2008 5:33:36 PM
ziggy
so whats wrong that you're taking it apart
Work Harder Millions on Welfare Depend on You
2009 Camo Big Bear 400IRS
28x10x12 EDLaw combo on stock rims
Warn 2500
BONE STOCK (but not for long)
EPI Clutch Kit (needs to be installed)
My Pics
RE: BB rear hub nut removel - 9/24/2008 8:24:55 PM
rockinred
something broak my grease fitting and i had to take it off toget the broak part out.
(in reply to ziggy)
0.563
