C1iffBurton
ORIGINAL: mud_dog450 quote:
ORIGINAL: C1iffBurton i know this dont have nothing to do with the seals, but i was greasing my joints yesterday and id stick it on the zerk and pump grease but it would only shout out of one of the 4 corners on the joint or sometimes 2 of the corners should i be worried at all or when it breaks it breaks? No need to be worried. That just means that you are putting too much grease in the joint and it is pushing excess grease past the rubber seals. YEA I FIGURED THAT, but didnt know if it should go through all the seals or not, the first time i greased them it came out of all of them but i have since rode alot and done alot of mud riding and i figured the mud maybe dried up around the rubber seal there and not letting the grease out no biggy when one fails and breaks then ill replace it
MINE*08 big bear 400, 27" skinny black love outlaws, CRSbear custom snorkel, Gumbo03 custom lift, oil cooler relocated, fan switch, audiopipe, viper 2500 max --TEAM ANYTING GOES RACING-- R.I.P. JAYSON MATTHEW PARKER
