Arctic Cat 700h1 vs Suzuki Kingquad 750
All Forums >> [Most Popular Discussions] >> Other ATV Topics >> Arctic Cat 700h1 vs Suzuki Kingquad 750 Page: [1]
Arctic Cat 700h1 vs Suzuki Kingquad 750 - 10/5/2008 5:10:26 PM
SouthernSuzuki
I'm looking to get a new quad soon and was looking at the Cat 700h1 and the King 750. I ride mostly trails, dirt roads, creeks, and some mud. Which of these quads would be best for trails? Which one of these would be the most reliable? Which one of these would I get the most use out of and have the least problems out of?
thanks
2005 Red Suzuki Vinson 500 Auto,
27" Outlaws on ITP SS106 Rims,
Full Ricochet Aluminum Skid Plates,
K&N Air Filter,
ATV Audiopipe,
Milano Gel Hand Grips
Amsoil Synthetic Oil,
1950 trouble free miles
2004 Yellow Suzuki Eiger 400 4x4 Manual,
26" Outlaw MST's mounted on Vinson Rims,
Fully Snorkeled
2007 Suzuki Z400 SE,
FOR SALE
1989 Chevrolet K5 Blazer 4x4:
Soon to have: 4" lift with 35"s
Soon to Come: Yamaha Grizzly 660 or
RE: Arctic Cat 700h1 vs Suzuki Kingquad 750 - 10/10/2008 9:49:47 PM
KS Cat
Go ride them both and pick the one you like.
2007 700 Cat on 14s
(in reply to SouthernSuzuki)
RE: Arctic Cat 700h1 vs Suzuki Kingquad 750 - 10/10/2008 11:24:47 PM
4man0822
ORIGINAL: KS Cat
      I own the 750 King & absolutely Love It! IMO! King for mostly trail riding & H1 for mudding! The H1 is waaaaaaaay heavier, but has a good bit better gc. The King is the faster of the 2 & more agile! Ride both & make your own decision, just use our recommendations for a guess!  Hope it works out for ya & let us know which 1                Brandon
4 a single, she hauls!!
filter, 27" Swamp Fox Plus, ATV Audiopipe, with the Bazookas(I love this thing)& **** 2500XT W/syn rope 05 500 Foreman 26"589 M+S 0n black C-4's, HMF Utility series, with jet, & UNI filter, boot guards& kimpex b
(in reply to KS Cat)
RE: Arctic Cat 700h1 vs Suzuki Kingquad 750 - 10/11/2008 9:22:10 AM
LiveForMud
to me it sounds like the king would be the better choice for your uses, but don't count out the cat just yet.
the king's advantages:
more power (dual overhead cams)
lighter (~80lbs)
better handling
slightly higher top speed
more "tunability" with the VDI
the 700H1's advantages:
MUCH better gearing (wider ratio CVT)
more gearing options
more ground clearance (stock)
more pulling power (weight and gearing)
more sitting and moving space (overall a larger machine)
speedrack system (if you have a lot of accessories)
Here's the specifics:
AC 650/700 H1 (37hp/41.5hp)
Primary (V-belt): 2.876 - 0.703
Secondary: 2.562 (41/16) [note: new 09+ secondary is slightly different]
Final:  3.6 (36/10)
Range Reduction                     (Overall)
High:  1.200 (30/25)             (31.831 - 7.781)
Low:   2.500 (40/16)             (66.315 - 16.210)
Rev:   2.000 (28/16x32/28)    (53.052 - 12.968)
With 3.1s (stock in 700 H1)
High:  1.200 (30/25)              (27.410 - 6.700)
Low:   2.500 (40/16)             (57.104 - 13.958)
Rev:   2.000 (28/16x32/28)    (45.684 - 11.167)
With 4.0s (stock in Mud Pro)
High:  1.200 (30/25)             (35.368 - 8.646)
Low:   2.500 (40/16)             (73.683 - 18.011)
Rev:   2.000 (28/16x32/28)    (58.947 - 14.409)
[I'm still trying to verify the new secondary reduction ratio in the 700 H1... i think it's about 4% lower but not sure yet... either way the cats have a huge advantage in low end gearing, even stock]
King Quad 700/750 (48.5hp/49.5hp)
Primary (V-belt): 2.763 - 0.78
Secondary: 1.904 (40/21)
Final: 3.6 (36/10)
Range Reduction           [Overall]
High: 1.240 (31/25)    [23.484 - 6.630]
Low:  2.563 (41/16)    [48.540 - 13.703]
Rev:   1.882 (32/17)    [35.643 - 10.062]
[there is a 16% reduction available to the king (eiger secondary drive gears), but it requires machining and a good bit of work]
if at some point in the future you decide to make it a mud bike i'd definitely get the H1... with 4.0s you're talking a hideous 52% lower low range starting ratio for the H1. and not to mention a MUCH stronger reverse (66% lower!!!)
the H1 just has gearing potential that the king doesn't. the king will handle a lot better stock since it's shorter and has better suspension geometry for sporty handling. cat offers a sway bar kit that really helps the cat handle much better than stock so it won't be too awful behind the king (the H1's taller ride height and heavier weight still give an advantage to the king).
don't worry about reliability or durability... both are about equal on that end. both have essentially the same CVT design amongst everything else. the king's biggest worry is the output shaft failures, while the H1s used to be plagued by secondary reduction failures (cat has redesigned the secondary to be much stronger this year though). both are EFI and are well-built.
take your pick...
2005 RED AC 500M
Remote mounted g.o.r.i.l.l.a. 3k lb winch
PC680 battery
iEquus 8068 3 3/8" tach
Reloc'd radiator
26-in XTRs
some other stuff
!seals, !brakes, !traction, !BEVEL GEARS, !money, !sanity...
Dad's ride- 06 Foreman S 4WD
Bro's ride- 07 King Quad 450
(in reply to 4man0822)
RE: Arctic Cat 700h1 vs Suzuki Kingquad 750 - 10/11/2008 10:46:40 AM
Voodoo
King for Trails
Cat for Mud
Voodoo
09 Outty 800R Red
HMF
PCIII
Woods 12:1 High Compression Pistons
(in reply to LiveForMud)
0.984
