mud_dog450 titleAndStar(4938,14,true,false,"Moderator","modavatar.jpg") Moderator Posts: 4938 Joined: 6/20/2004 From: North Central Ohio Status: offline Danny is a good guy, but his products aren't so much. I ordered a CV rebuild kit from him, installed it, and the next ride it broke. I tried to get it Warrantied by him, but he told me they don't do Warranties on rebuild kits since they don't know the condition of the outer CV cup when it was installed. As a mechanic (and a Warranty Technician), I found his point to be valid and decided to order 2 half-shaft kits. The very next ride after installing the new half-shaft, the outer CV cups' inner cage shattered. I told him and he asked for me to return the entire axle (the inner CV joint was the OEM, mind you) and he would take a look at it and let me know. I offered to return BOTH half-shaft kits that I purchased for a full refund of my money, but that offer wasn't an option. A week went by and my OEM inner joint shows up at my place with a rebuilt half-shaft installed. On the invoice it stated that they found wear on the outer CV cup that indicated that I was running a lift kit and that this is the last time this would be considered under Warranty. Well that's all fine and dandy except that I do NOT have a lift kit, not even a 2". Again, I found him to be a good guy, but his products need some overhauling before I would consider using them again outside of my Warranty. < Message edited by mud_dog450 -- 8/18/2008 7:08:49 PM > _____________________________ The Mud Brothers Goin' Deep Since 2004! 02 Grizz Everything Snorkeled Clutch Work 26" 589s Muddin _____________________________________________________________________________ all i cant say is i will take him for his word, 26"589s and no lift, and no more warrenty...?
08 650H1 LE Warn 3.0 Snorkeled,Rad relocated Custom mounted gauges muffler tweaked Dynojet, slide mod, spring clipped Custom clutch kit, 4.0 gears HL springs, HL spacers "G" axles 29.5 Laws on custom LE wheels 30" MLs on Black Castle Roks 05 500m Dynojet,slide mod spring clipped muffler tweaked Hidden snorkel HL temp gauge 26" 589MTs on ITP type 6s Hard.Pack.Arctic.Cat
