EZRIDER lets rock
I have put 7 grease fittings in mine 1 on each upper front a-arms, what I found is when you pump grease in them it will start to push the seal out on one end, their is a gap between the seal and the mount, (a washer of the correct size could take care of that) however does work. I put a fitting in the top and bottom of the rear hub bushings, I figured the hubs would brake? i,m running 27 laws and they have held up so far. and I put one in the foot brake, so far all has worked out ok, I do have to pull the rear tires to grease the rear hub bushings tho.
somebody hold me beer, I got to go get mario,s he,s broke again!! WWMD???
