ATV Implements
ATV Implements
All Forums >> [Most Popular Discussions] >> ATV Accessories >> ATV Implements Page: [1]
ATV Implements - 8/18/2008 12:30:51 PM
Redneck Ron
I am looking into getting some ATV implements for trail work.  Does anybody have any experience with these and what kind do you like?  These **** things are expensive and want to get right the first time.
RE: ATV Implements - 8/18/2008 8:24:35 PM
southern boy
if you need a plow biologic makes one that is excellent. you can pic one up for about $600
99 forman 450es: warn winch interco swamplites
FOR SALE 04 400ex: head from '05, origynal cylander bored up 2mm, wiseco high compression piston, brand new gaskets, fmf slip-on, houser +2 a-arms, rebuilt rear shock, durablue wheels spacers, kenda klaws on all fours, ac front bumper, dg nerfs, renthal handlebars, tether kill switch, powermad hand gaurds, black maier racing plastic, K&N air filter, shockwears
(in reply to Redneck Ron)
RE: ATV Implements - 8/18/2008 8:42:39 PM
AtlBruteForce
Yes you are correct...  they are very expensive.  What are you looking for?  Disc harrow, plow or buster, drag, cultipaker, or an "all in one"?  Lots of choices out there.  Check out the PlotMaster Hunter 400.  Wow!  It will set you back over $ 3000.  Here is a good couple of websites:
http://www.theplotmaster.com/
http://www.biggamehunt.net/sections/Hunting_Gear_and_Products/ATV-Accessories-for-Food-Plot-Maintenance-05290812.html
Good luck
2006 Brute Force 750 Camo
still stock but looking for tires/wheels and some music
(in reply to southern boy)
RE: ATV Implements - 8/18/2008 8:44:27 PM
ubba Aldridge
Just rent a tractor and disc, and be done quicker and better. Also cheaper.
>>>follow>>>>>my>>
>>>>>>>>tracks>>>>
2005 Rincon *26" DU Wetlands *3000 Warn
2003 Polaris SP 500HO *27" Mud Bugs *3000 Ramsey
2007 Polaris SP 500HO EFI X2 Camo
http://www.photoshow.com/watch/kq3NZ5Gg
http://www.photoshow.com/watch/eH2Zz2ss
http://www.photoshow.com/watch/HR7ya3ny
http://www.photoshow.com/watch/kR5Sb2sR
(in reply to AtlBruteForce)
RE: ATV Implements - 8/18/2008 8:59:24 PM
lonegunman
you wanting to do trail work?   i have a tow behind bush hog i use with my wheeler. it is made by swisher. works for what i need to get done.
lonegunman
TEAM TOXIC MOTORSPORTS
WWW.TEXARKANAMUDHOS.BLOGSPOT.COM
www.myspace.com/lonegunman0717
2001 arctic cat 300 4x4
lift kit
26" dirt devils
rokstar wheels
snorkeled
jetted
ion halogen driving lights
2500 warn winch
2007 a/c 650 H1-RED
LE wheels
front brush guard
LE rear bumper
28 mudlites
warn winch
H.P.A.C.
It all seems hardpack when you ride a cat
(in reply to ubba Aldridge)
RE: ATV Implements - 8/18/2008 9:25:28 PM
Redneck Ron
I was looking at Koplin dirtworks equipment 3 point system with 48 in blade.
(in reply to lonegunman)
RE: ATV Implements - 8/19/2008 7:49:58 AM
Jake450s
What sort of "trail work" do you anticipate doing?
The reason that I ask is that there are hundreds of things  you can bolt on to a four wheeler, many are part of a "system" that makes like branded implements easy to attach and switch.  Most (but definately not all) are of excellent quility and probably worth the insane prices that they command.
What I have not seen, is the sort of implement you're seeing actually work out on a trail.  ATVs aren't earthmovers, they can't tear out roots and boulders.  Disk harrows are too light to "flatten" existing trails, and  you really don't want to anyway, you want to pack a trail in (adding gravel or similar) versus tearing it up...
The thing I have ever seen work out on a trail maintenance crew is a drag behind brush hog style mower, and pretty much that is for fields and meadows, to define the allowable area.  It's not terribly "off road capable", it had to be picked up and carried in a better suited wagon over a good chunk of trail.
if we knew better what it is you are trying to accomplish, we'd be much better able to assist.
RE: ATV Implements - 8/19/2008 8:32:26 AM
Ay4alex_420
Kolpin stuff looks good
2008 Red Honda Rancher 420 4x4 ES
Warn XT30 - Go Prepared.
My Lights Go Blinky Blinky
The Polaris Forum Was Created For Full Time Mechanics Only!
TEAM XTREME 4X4 OFFROAD
(in reply to Jake450s)
RE: ATV Implements - 8/19/2008 10:45:45 AM
Redneck Ron
There is a group I ride with that does trail maintenance with the forest service.  We have been at it for the last couple of year through pick and shovel work.  I wanting to speed the process up some by putting a little metal to the ground and fixing some areas a little more swiftly.
(in reply to Ay4alex_420)
RE: ATV Implements - 8/20/2008 8:38:17 PM
Sportsman762
I am not sure what your trails entail but if they are in the woods then an atv implement is not going to help you.  You would need a four wheel drive compact tractor with heavy duty implements to stand up to the abuse of trail maintenance.  Look at a rental company and rent a tractor with the implements.  I would suggest renting instead of borrowing someones because of the wear and tear on implements.  However if your trails are through open areas with a loose soil then an atv implement might work for you.  For the price of an atv implement you can rent a tractor allot.  If you want a cheap tractor to use get an older 2wd Industrial tractor with a loader.  It will be big but it can take the abuse from trail maintenance and they can be found for around $4000.
- 2001 Sportsman 500HO 3500lb Mile Marker winch, Dual Batteries, Front and Rear Bumpers, 700 Front Springs, 25" Bearclaws in front, 25" Tracker P in rear, Receiver Hitch, more small things.
- 2004 Trail Boss 330-stock
RE: ATV Implements - 8/24/2008 8:27:32 PM
kyguy076
I have a 24 inch brush mower for sale. It is a walk behind but will cut saplings up to 1 inch in diameter. Swisher brand Still on it's first tank of gas. $700.
2006 Polaris 800 green 27inch Titan 589's ,bushguard,4000 lb VIPER Winch and Audiopipe.
(in reply to Sportsman762)
0.563
