bansheefan03
ORIGINAL: Black Redneck if you ride a honda with a sra, a body lift is all you get. even when you put the spring lift on it just makes the frame a little higher so you can put bigger tires on it. other than putting IRS on it or chopping the swingarm and extending the driveshaft, you're p!!ssing in the wind. why is it pissing in the wind just cause its a sra i bet that kitty cat could not go half the places that sra goes
2006 rhino 660 29.5 swamplites,lift,rear steer,snorkled 98 300 376 bbk,4.5mm stroked crank,ported head,ids2,snorkle,lift,body lift,locker,EDL/ ****s ,axle paddle,459 cam,gear reduction,clutch kit,warn 424,chrome XL2 wheels,katana oil cooler,400ex carb soon to come ex head, disc brakes 98 300 not really sure how much lift, ape axles,gear reduction,xl2 wheels, axle paddle,and lots more to come
