96 kodiak smoking
96 kodiak smoking
All Forums >> [OEM Discussions] >> Yamaha >> 96 kodiak smoking Page: [1]
96 kodiak smoking - 7/23/2008 3:40:37 PM
1porknbean
i bought with bike a few months back and have only taken it out one time but noticed it smokes real bad at first but then quits smoking after about 15 to 30 minutes, i know the guy that bought it put in a jet kit but still has the original exhaust.  if you jam down on the throttle off the jump it bogs down and tries to stall, i figured all this was connected to the jet kit, does anybody have any info that could help me, and where can i get the original jets.
RE: 96 kodiak smoking - 7/24/2008 4:15:13 PM
1porknbean
someone has got to have some input!!!
(in reply to 1porknbean)
RE: 96 kodiak smoking - 7/24/2008 4:34:55 PM
Dezz
If a Jet Kit has been added without any modifications to the exhaust or the intake, it might just be jetted incorrectly. You can still install a jet kit without any mods, BUT, it gives you no benefit. Since someone has played with it for no reason though, it might not have been correct.
Check the spark for color. It should be tan brown. If it black, then it is running rich. If it is white, then you are running lean.
Running rich could be the reason for the smoke. Which leads to the other question.......
What color smoke is the engine producing? Blue, Black or White?
Dezz
1998 Grizzly 600
27 inch ITP Blackwater XT tires
ITP Black Chrome Rims
Uni Air Filter
Warn A2000 Winch
Other than that, Stock. It works!!!
RE: 96 kodiak smoking - 7/24/2008 5:53:09 PM
1porknbean
blue
(in reply to Dezz)
RE: 96 kodiak smoking - 7/24/2008 6:08:16 PM
Aussie Bloke
if its blue smoke then its using oil .let it idle for 5min the rev it up quick bursts of the accelarator to full revs .dont hold it on full revs just on and of.
if a heap of blue smoke comes out its ither the rings or valve stem seals.
sorry for the bad news.
also check the oil level after a days riding .
08 yam 700 blue bullbar full racks front &rear 100watt spots 55watt rear, 05 kodiak 400 roo bars and racks back & front.
100 watt spots
RE: 96 kodiak smoking - 7/24/2008 8:33:34 PM
1porknbean
what if it's white smoke, it was hard to tell cus i was in the garage
(in reply to Aussie Bloke)
RE: 96 kodiak smoking - 7/24/2008 8:35:13 PM
1porknbean
anybody got any good links to adjust the carb and the jets???
RE: 96 kodiak smoking - 7/28/2008 11:43:17 PM
1porknbean
well i took it out of the shed today to play with it and let it run for a few minutes and the smoke clears up, and it's white not blue.  it is snorkled and the spark arrestor is removed but still bogs down real bad when i get on the gas.  like i said i know it has been jetted, i guess the question is should i go to the yamaha shop and get the original jets or what do ya'll think, i don't wanna go out on my next outing looking like i am fogging skeeters
RE: 96 kodiak smoking - 7/29/2008 5:44:49 PM
1porknbean
ttt
RE: 96 kodiak smoking - 9/6/2008 12:17:13 AM
dennyb_of_raleigh
Best place to get jets is jetsrus dot com ... 105 is the factory main jet size.
Old Skool ('97) Yamaha Kodiyakyak ... thought it was used, turned out to be abused!!
27 in. 589's, ITP type 4 rims, 2 in. lift, snorkeled, DG muffler, K&N, rejetted (115 main), DG bumper, temp gauge, EPI perf. clutch kit, relocated oil cooler & fan, custom front disc brake conversion ... never finished ....
RE: 96 kodiak smoking - 9/6/2008 9:51:30 AM
DEEZ
I noticed this tread is a couple mths old, but anyway.
Located in the tech forum
http://www.highlifter.com/forum/Helpful_General_Tech_Threads/m_2774885/tm.htm
And you asked what if it was white smoke. This is what I had to go through
http://www.highlifter.com/forum/m_2777723/mpage_1/key_/tm.htm#2891454
07 Yam Grizzly 450
27" outlaws
Highlifter 1.5/2" lift kit
Backup light that works only in reverse & headlights on
Reverse rev limiter mod to the bypass button
Snorkled intake, beltdrive & sometimes exhaust
All 5 vent lines run to handlebars
Axle guards
K&N filter, Dynojet kit
My pics
4sale
plug
(in reply to dennyb_of_raleigh)
0.344
