gordo
The carb vent tube comes out the left upper side of the carb and turns and runs up the airtube,,,, you have little knurls on the airtube that it sits between. The carb drain tube comes out the bottom side of the carb and just hangs down with the crankcase vent line. The carb drain has a one way valve at the bottom to prevent water from coming in,,,,
Hello everyone,,, my name is gordo and I'm a Fourtrax addict,,,, 2000 Honda Fourtrax Warn 424/Warn 2500 Winch HL Front Disk Brake Kit/Snorkeled 1997 Honda Fourtrax Warn 424/Viper 2500 Max Winch HL Front Disk Brake Kit/Snorkeled 1996 Honda Fourtrax HL Disk Brakes/Warn 424 G o r i l l a XT3000 Winch/Snorkeled 1990 Honda Fourtrax Warn 424/Viper Max 2500 Winch HL Disk Brakes PM me for info on good cheap trailers!
