700 grizz transmission??
All Forums >> [OEM Discussions] >> Yamaha >> 700 grizz transmission?? Page: [1] 2   next >   >>
700 grizz transmission?? - 8/11/2008 9:07:52 AM
longside450
ok something is up with my bike and i have no idea what it is. i was doing about 6 mph on a trail when it started making a loud clack noise and nosediving. it sounds like its either coming from the tranny or the clutch. i haven't had a chance to pull the housing cover off yet to scope things out in there but has anyone had this problem before? it sounds like maybe a gear is broken or something, it does it in Hi, Low, and Reverse but not in neutral. any help would be appreciated, thanks.
07 700 Grizzly SE
735 big bore kit, Wiseco 11:1 piston, Webcams cam, 29.5" Outlaws on SS112s, 2" lift kit, HL lift springs, 1/2" spacers on front springs, HMF pipe, HMF optimizer, EHS modded airbox lid, UNI air filter, snorkled belt housing and exhaust, relocated radiator, EPI clutch kit, full Yamaha skid plate pkg, Yamaha front & rear bumpers, red LEDs on headlights, hyperwhite headlights.
RE: 700 grizz transmission?? - 8/11/2008 9:17:24 AM
undisputedattitude
Never heard of this before,hopefully someone can help you out.
07 Grizzly700,Warn Winch,EHS PowerTip,Pod Mod,HID lights,shockwears,27"zillas on ss212s.
(in reply to longside450)
RE: 700 grizz transmission?? - 8/11/2008 9:28:22 AM
scott m
one way bearing may have came apart.
CAJUN SWAMP DAWGS
HIS: 07 GRIZZ 700
29.5 LAWS ON SS112'S
HMF
OPTIMIZER
TWIN A/F
DYNA IGNITION SYS
EPI CLUTCH KIT
2" HL LIFT
SPACERS
MONKEY CV'S
HANGER MOD
HERS:06 GRIZZ 660
27" XTR'S ON ITP'S
EXTREME LIFT
HMF
K&N
JETTED
BAYOU SNORKLE
LIFT SPRINGS
GOR!LLA AXLES
CUSTOM PINK TRIMWORK
GEAUX DEEP OR GEAUX HOME
R.I.P. JAYSON MATTHEW PARKER, HONORARY SWAMPDAWG
http://www.myspace.com/scottmor
(in reply to undisputedattitude)
RE: 700 grizz transmission?? - 8/11/2008 9:36:36 AM
longside450
where is that at?
07 700 Grizzly SE
(in reply to scott m)
RE: 700 grizz transmission?? - 8/11/2008 10:03:10 AM
scott m
inside the clutch housing, its what gives you your engine braking.  most time when it goes out u just have no engine braking, but my buddy had a 700 in his shop that was doing the same thing you're describing and it was a broken one way bearing.   about a $150 fix with labor.   i'm sure hormel knows about em.
CAJUN SWAMP DAWGS
HIS: 07 GRIZZ 700
HMF
OPTIMIZER
TWIN A/F
DYNA IGNITION SYS
EPI CLUTCH KIT
2" HL LIFT
SPACERS
MONKEY CV'S
HANGER MOD
HERS:06 GRIZZ 660
27" XTR'S ON ITP'S
EXTREME LIFT
HMF
K&N
JETTED
BAYOU SNORKLE
LIFT SPRINGS
GOR!LLA AXLES
RE: 700 grizz transmission?? - 8/11/2008 10:03:46 AM
sscard
its inside clutch housing
probably not a bad idea to dissasemble the clutch and check it out and then tell us what you found in there
could also be a gear, I cant remember which gear caused that, but someone I know had a  700 at nationals and his did this
look for one of the dorcheat diggers group and they can help you if its not the one way bearing, vampirekitty can get you to him, shes usually in the nationals threads
I think he called it a bevel gear in the transmission, couldnt tell you how big of a deal that one is though
04 Grizzly 660 camo
TRIPLE Flow
The Wifes
02 Rancher 350 4x4
Pink Dipped Plastics
RE: 700 grizz transmission?? - 8/11/2008 10:09:17 AM
longside450
sweet, that would be awesome if it was just 150 to fix it, lol. thanks for the insight, i'm gonna take a look at it when i get off of work and let ya'll know
07 700 Grizzly SE
(in reply to sscard)
RE: 700 grizz transmission?? - 8/11/2008 10:12:08 AM
scott m
dont forget to drain your oil.
CAJUN SWAMP DAWGS
HIS: 07 GRIZZ 700
HMF
OPTIMIZER
TWIN A/F
DYNA IGNITION SYS
EPI CLUTCH KIT
2" HL LIFT
SPACERS
MONKEY CV'S
HANGER MOD
HERS:06 GRIZZ 660
27" XTR'S ON ITP'S
EXTREME LIFT
HMF
K&N
JETTED
BAYOU SNORKLE
LIFT SPRINGS
GOR!LLA AXLES
RE: 700 grizz transmission?? - 8/11/2008 10:13:43 AM
sscard
scott
am I right on the bevel gear?  have you heard of that one before?
It was some guys camping next to me, he seemed to know what he was doing, he came to our camp, drank a few beers and helped me change a bad timing chain, and was quick a realigning the side case oil gears, which takes me a few minutes to think through
04 Grizzly 660 camo
TRIPLE Flow
The Wifes
02 Rancher 350 4x4
RE: 700 grizz transmission?? - 8/11/2008 10:14:09 AM
longside450
what do i need to drain the oil for?
07 700 Grizzly SE
RE: 700 grizz transmission?? - 8/11/2008 10:26:48 AM
scott m
sscard, i'm not sure about the bevel gear--it could be that as well. i just never came across this.  i onlly suggested th 1way because i just saw a 700 with a very similiar problem, but you are right, could be the other as well.  longside, the one way bearing is inside the wet clutch.
CAJUN SWAMP DAWGS
HIS: 07 GRIZZ 700
HMF
OPTIMIZER
TWIN A/F
DYNA IGNITION SYS
EPI CLUTCH KIT
2" HL LIFT
SPACERS
MONKEY CV'S
HANGER MOD
HERS:06 GRIZZ 660
27" XTR'S ON ITP'S
EXTREME LIFT
HMF
K&N
JETTED
BAYOU SNORKLE
LIFT SPRINGS
GOR!LLA AXLES
RE: 700 grizz transmission?? - 8/11/2008 10:31:22 AM
longside450
o ok, i've never had to do anything with the clutch so i'm new to all of this.
07 700 Grizzly SE
RE: 700 grizz transmission?? - 8/11/2008 10:46:30 AM
sscard
I am not saying for sure it is bevel gear, I am not a transmission guy
I can fix clutch and motor, not tranny
I would agree on checking one way bearing first, the bevel gear is buried in the tranny not in the clutch on the outside, check that first for sure
are you not under warranty?
04 Grizzly 660 camo
TRIPLE Flow
The Wifes
02 Rancher 350 4x4
RE: 700 grizz transmission?? - 8/11/2008 10:51:39 AM
Molsondrinkr
ORIGINAL: longside450
If you don't drain it before pulling the wet clutch cover, you will have oil every where.  Also you better go ahead and order the gasket as they normally can't be reused.
For the 700 the part# is 3B4-15463-00
I had what sounds like a similar issue with mine.  All of a sudden my clutch was making a horrible noise.  I shut it down right away and pulled it out of the bush.  Got it home and pulled everything apart, only to find nothing.  I put it all back together thinking it was internal, and I would have to take it in.
After I got it together, I fired it up anyway and all was good.  Been good ever since.  I suspect the one way bearing was bound up somehow, as it was the only piece that had any marks on it.
There is a post of my ordeal on here somewhere.
2007 700 Grizz
28" MST's
Twin Air Filter
Billet Tip
TFI Controller
Ricochet Arm Guards
Dyna CDI
Full 2" Snork's
4 Kodi weights
08 Polaris RZR
with stuff
RE: 700 grizz transmission?? - 8/11/2008 10:53:29 AM
longside450
warranty?? the warranty was void before i even saw the bike, lol.
07 700 Grizzly SE
RE: 700 grizz transmission?? - 8/11/2008 2:17:10 PM
nicks450r
Look up DorcheatGrizzly. It was the bevel gear that broke at Nats. It had the same initial symptoms.
TEAM DOUBLE D
"DORCHEAT DIGGERZ"
" FLIP-FLOP"
2007- GRIZZ 700 FI BLUE
31" x 9.5" OUTLAW's
ITP SS112's
HL 2" LIFT
HL 1 1/2" SPACERS F&R
HMF EXHAUST
STICK STOPPERS F&R
CUSTOM SNORKEL
2003 CHEVY Z71,- 6" SUPERLIFT, MICKEY THOMPSON CLASSIC II'S, 315/75/16'S, FLOWMASTER SUPER 40'S DUMPED, K&N FILTER
www.flickr.com/photos/nicks450r/
RE: 700 grizz transmission?? - 8/11/2008 2:22:17 PM
nicks450r
ORIGINAL: nicks450r
Look up DorcheatGrizzly (Jay Gore). It was the bevel gear that broke at Nats. It had the same initial symptoms. It was a complete engine tear down. Only took him about an hour and a half to tear down, split the case, and completely reassemble. He is my best friend and by far the fastest most effective mechanic that     I         have ever seen.
TEAM DOUBLE D
"DORCHEAT DIGGERZ"
" FLIP-FLOP"
31" x 9.5" OUTLAW's
ITP SS112's
HL 2" LIFT
HMF EXHAUST
STICK STOPPERS F&R
CUSTOM SNORKEL
(in reply to nicks450r)
RE: 700 grizz transmission?? - 8/11/2008 4:08:06 PM
sscard
I knew someone knew jay
we saw him at srr after nationals, I was the one he helped "he did all the work" replace my timing chain on my grizzly
Shane
04 Grizzly 660 camo
TRIPLE Flow
The Wifes
02 Rancher 350 4x4
RE: 700 grizz transmission?? - 8/11/2008 5:12:01 PM
farmerboy700
most likely the one way bearin mine has went out on my 700, if u can still ride it it aint broke yet mine completly broke and trust me u will know when it breaks
''TEAM DO WORK''
700 Grizzly Fi.
WID SOME EXTRAS!!
03 MONKEY LIFTED 660 GRIZZ
WID A FEW GOODIES!
RE: 700 grizz transmission?? - 8/11/2008 5:28:34 PM
longside450
i can't ride it, it's like the wheels lock up at certain points when it makes that loud clacking noise
07 700 Grizzly SE
(in reply to farmerboy700)
RE: 700 grizz transmission?? - 8/11/2008 5:40:06 PM
sscard
that really sounds like the one way bearing more and more, the bevel gear would always do it, it wouldnt move at all
04 Grizzly 660 camo
TRIPLE Flow
The Wifes
02 Rancher 350 4x4
RE: 700 grizz transmission?? - 8/12/2008 1:48:23 PM
longside450
i tried searching for DorcheatGrizzly but i can't find anything. i'll be pulling the housing off after work this afternoon so i should have a better idea of what to expect as far as damage goes
07 700 Grizzly SE
Post #: 22
RE: 700 grizz transmission?? - 8/13/2008 2:07:21 PM
Dorcheat Grizzly
try it in neutral if engine runs ok one way bearing sould be ok
belt will turn in neutral with some throttle
try in for, or rev, if popping noise heard in bevel gears
some teeth broken off some are not
bike will pull on good teeth and pop or lock up on broke teeth
gear set 300.00 plus case has to be split
07 700 gizzly camo
29.5 swamplites ss112
hmf and opm
custom snorkel
2 in lift
custom brass brakes pads
04 trx450r
k&n filter
jet kit
sand tires
Post #: 23
RE: 700 grizz transmission?? - 8/13/2008 3:56:41 PM
sscard
theres jay
he knows if anyone knows
04 Grizzly 660 camo
TRIPLE Flow
The Wifes
02 Rancher 350 4x4
(in reply to Dorcheat Grizzly)
Post #: 24
RE: 700 grizz transmission?? - 8/13/2008 6:50:33 PM
longside450
ok whether i put it in forward or reverse it pulls then locks up, pulls then locks up. if i put it in neutral it doesn't make any kind of noise or anything. i shoulda figured it was the more expensive of the 2 that was broken, lol.
07 700 Grizzly SE
Post #: 25
RE: 700 grizz transmission?? - 8/13/2008 7:41:12 PM
farmerboy700
thats exactly what mine done when the one way bearin went out!!
''TEAM DO WORK''
700 Grizzly Fi.
WID SOME EXTRAS!!
WID A FEW GOODIES!
Post #: 26
RE: 700 grizz transmission?? - 8/13/2008 8:58:47 PM
Dorcheat Grizzly
always check easy first. i would check oil drains for metal at engine and diffs. if metal found in engine i would  pull belt housing and wet clutch housing off and check for damage. if clutch and bearing ok it must be bevel gears (yamaha calls middle drive gears). to be sure u can remove rear diff and remove output shaft housing (careful to save shims) . it will just side out back of engine
07 700 gizzly camo
hmf and opm
custom snorkel
2 in lift
04 trx450r
k&n filter
jet kit
sand tires
Post #: 27
RE: 700 grizz transmission?? - 8/19/2008 9:59:03 AM
longside450
i pulled everything off that's behind the clutch housing cover up to the bearings, all i have is the back cover thats still bolted to the engine/tranny and the shafts coming out of the engine/tranny. which one has the 1 way bearing, engine or tranny? this is the first time i ever mess with any of this so i'll have a lot of questions, lol.
07 700 Grizzly SE
Post #: 28
RE: 700 grizz transmission?? - 8/19/2008 10:37:31 AM
Molsondrinkr
It's in/behind that housing that you still have bolted to the engine.  Unbolt it, and give it a tug.  The shaft,housing and everything will all come off as one piece. You will see it then.
You did drain the oil already?  If not, do it before you unbolt the housing.  And like I said before, you will need a new gasket for re assembly.
2007 700 Grizz
28" MST's
Twin Air Filter
Billet Tip
TFI Controller
Ricochet Arm Guards
Dyna CDI
Full 2" Snork's
4 Kodi weights
08 Polaris RZR
with stuff
Post #: 29
RE: 700 grizz transmission?? - 8/19/2008 10:40:57 AM
longside450
no, i didn't drain the oil yet, it was getting late when i was messing with it but i'll go get a gasket and drain it this afternoon. thanks for that info. are there any parts that i have to worry about falling out or anything like that?
07 700 Grizzly SE
(in reply to Molsondrinkr)
Post #: 30
Page:
