700 and 660 wet clutch similarities
All Forums >> [OEM Discussions] >> Yamaha >> 700 and 660 wet clutch similarities Page: [1]
700 and 660 wet clutch similarities - 8/27/2008 7:39:08 AM
XLCat
Has anyone examined each wet clutch to see how similar they are?  The reason I ask is that Hauck offers high stall springs for the 660 but not the 700 yet.  If they're close enough, I may just pop for the 660 springs and try it out.  What are yall's thoughts?
2007 700 GRIZZLY---Outlaw MSTs: 26x9.5, 26x12; Warn 3000 w Amsteel, (4) CEC 1" spacers, UNI air filter, 1.25" bar relocation, removed shifter lockout, exhaust tip, 9003 SilverStars, (8) 660 weights
1986 TRX200SX parts donor
1985 ATC70---detailed, open air filter, gutted exhaust, jetted, 200sx throttle housing & cable, stripped everything that doesn't make it go!
RE: 700 and 660 wet clutch similarities - 8/27/2008 2:15:52 PM
XLCat
Anybody?
(in reply to XLCat)
RE: 700 and 660 wet clutch similarities - 8/27/2008 2:24:25 PM
txjgrizz
I read on someone's site that the 700 springs did not need to be changed because they were adequate from the factory, unlike the 660. If I find where I read that I will let you know.
'02 660 Grizzly:
29.5-12 Laws or 29.5 Swamplites, Viper 3500lbs wp Winch, Snorkeld Belt Housing & Vents, HL radiator/fan, Xtreme 2" & HL Springs, Swamp Series XL; Airbox mod & snorkel
(in reply to XLCat)
RE: 700 and 660 wet clutch similarities - 8/27/2008 2:54:53 PM
If its set up for stock size tires then it can be made better when useing larger tires... JMOP
is there a online part diagram you can look at them somewhere to see if the part numbers might match up.. i would bet they are the same. well lenght anyway might have alittle different stall to them..
08 650H1 LE
Warn 3.0
Snorkeled,Rad relocated
Custom mounted gauges
muffler tweaked
Custom clutch kit, 4.0 gears
"G" axles
29.5 Laws on custom LE wheels
30" MLs on Black Castle Roks
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
26" 589MTs on ITP type 6s
Hard.Pack.Arctic.Cat
(in reply to txjgrizz)
RE: 700 and 660 wet clutch similarities - 8/27/2008 3:01:42 PM
XLCat
Yep.  The 700 engages at barely off idle.  I think the spring the site is most likely referencing is the secondary spring.  It's supposedly much better than the 660.  But it definitely needs a little more rpm before engaging.
(in reply to GWC)
RE: 700 and 660 wet clutch similarities - 8/27/2008 3:57:59 PM
mud_dog450
Part numbers are the same except for the model-specific-prefix.  I think they are different.
5KM for the 660.
3B4 for the 700.
The Mud Brothers
Goin' Deep Since 2004!
02 Grizz
Everything Snorkeled
Clutch Work
29.5 Laws on Vision Buckshots
Muddin Videos
(in reply to XLCat)
RE: 700 and 660 wet clutch similarities - 8/27/2008 4:06:44 PM
JB3231
I've got a set of 700 wet clutch springs and the gasket from Yamaha for sale.  $75 shipped for both.  PM me if interested.
(in reply to mud_dog450)
RE: 700 and 660 wet clutch similarities - 8/28/2008 7:27:34 AM
XLCat
If anybody has a set of factory 700 wet clutch springs, I'd like to get my hands on one.  If interested PM me.  Thanks
(in reply to JB3231)
RE: 700 and 660 wet clutch similarities - 8/29/2008 2:46:48 PM
XLCat
Does anybody have any info on the factory or aftermarket springs?  Physical dimensions or spring rates?
(in reply to XLCat)
RE: 700 and 660 wet clutch similarities - 9/4/2008 8:00:50 AM
XLCat
Wanted to bump this back up to the top.  Also, I installed a .065" shim in the primary yesterday with good results.  Didn't loose any top speed, but did notice it revs out more at my constant top speed of 58-59mph.  Wheelie factor definitely went up in L.  That's about as thick a shim as you can go and still have spline engagement on the cam plate.  The ID of the shim is .750 and the OD is 1.375.  I thought that was odd since it's all supposed to be metric...
(in reply to XLCat)
RE: 700 and 660 wet clutch similarities - 10/2/2008 9:10:29 AM
XLCat
Wanted to bump back to the top.  I'm still looking for one or a set of factory 700 wet clutch springs.  Any help would be greatly appreciated!!!
(in reply to XLCat)
0.594
