660 front drive shaft?
All Forums >> [OEM Discussions] >> Yamaha >> 660 front drive shaft? Page: [1]
660 front drive shaft? - 7/21/2008 12:00:53 PM
03 Grizz
Does anybody know how hard it is it to take the shaft out?  Does it have grease in it just like the cvs? My boot is ripped.
2003 Yamaha Grizzly
29.5 12 outlaws all 4 corners on Itp black ss108
Highlifter xtreme clutch kit
Warn winch with warn rope
Warn front bumber
Custom snorkel with k&n and outerwears pre-filter
Hmf pipe with quiet core
RE: 660 front drive shaft? - 7/21/2008 12:05:47 PM
matt660
It's easy.  You can take the front differential bolts out and slide the front diff forward.  The way I do it is take the short bolts that hold the diff out, loosen the long one, and pry the front differential straight up.  I can have that driveshaft out in 12 or 15 minutes.
05 Grizzly
98 Bear Tracker
http://community.webshots.com/user/Matt660
(in reply to 03 Grizz)
RE: 660 front drive shaft? - 7/21/2008 12:08:34 PM
justgiver
I don't think you can change the boot though. Or can you? Not sure if the CV comes off the shaft.
(in reply to matt660)
RE: 660 front drive shaft? - 7/21/2008 12:12:43 PM
matt660
I'm not sure of that either.  I know you can't buy the joint but not sure about the boot.
05 Grizzly
98 Bear Tracker
(in reply to justgiver)
RE: 660 front drive shaft? - 7/21/2008 12:26:19 PM
ectrip78
with matt 660                i   do it the same way its easy and i could not find the boot i had to bye the shaft and make sure you look at both ends were tha sheft gos on the diff and the one on the moter i would replace all3 pieces  i have a 03 and had a tore boot win i tore it apart it was crap the splins are tiny and wore out so i did it all with new seals
03 660 grizzly/28 laws on chrome ss 112s/hot cam/jet kit/cdi/full skid and a arm plates/winch/rev box/full snorkel kit/exhaust//2inc lift /hl clutch kit/rad relocated the works but not done
RE: 660 front drive shaft? - 7/24/2008 3:49:28 PM
rokke17
So I can just pull the front diff mount bolts out and that will give enough movement to slide it forward and get the driveshaft out?  My warranty expires soon and I want to get a new shaft while i still can.
"Red"
07 Grizz 660
Warn Winch
27" MSTs
Homemade SETX style snorkels
HMF Penland Pipe
(in reply to ectrip78)
RE: 660 front drive shaft? - 7/24/2008 3:57:33 PM
rabbit1804
that is correct
TEAM ****
08 THUNDERCAT
02 Vinson
Wins 2008
2nd Texas Mud Jam Mudbog 500 class
2nd Firecracker Bash Doles, GA. Swamp X 500 class
2nd Bayou MudRacing Minden, LA. SwaMP-x 500 Class
3rd Texas Stadium Mudfest Bogger class Fri. Night
3rd Texas Stadium Mudfest Bogger Class Sat. Night
2nd Can-Am Nationals Swamp-X 500 Class
(in reply to rokke17)
RE: 660 front drive shaft? - 7/25/2008 3:47:25 PM
GrizzWise
When in heck is Gor!la Turner cycles gonna come out with a front shaft for the 660's????? I think its rediculous to make one for the rear and not thr front...JMO
FOR SALE:
07 Grizzly 660
31 x 9.5 LAWS, HL xl2's, Gor!la Axles, HL Radiator, HL Temp Gauge, EPI Clutch, Bayou Snorks, HL Lift & Springs, HMF Penland, Power Now!, DynaTek, Dynojet, UNI Filter
ORIGINAL: ExtremeForce
but thank you for your input.GrizzWise.and i will add that my brute has a 2" lift and the grizz is bigger and faster.were running the same size tires.so it made since to me
GrizzWise:
hahahaha!!!
(in reply to rabbit1804)
RE: 660 front drive shaft? - 7/25/2008 4:07:17 PM
YAMAFORD
ORIGINAL: rokke17
So your wanting to replace the boot before you take it in for warranty? If thats the case find an automotive axle repair shop, take them the old boot. YAMAHA does not make the boot therefor someone should be able to find it. there is a code on the side of most boots that you can match up.  Yes you can take it apart.
Kelvin " MuD PiT MafiA "
http://www.creekbottomtrailrides.com/
MINE
04 660 black
27x10 SB's snorkle, rad relocate, 1 ****, 686, clutch kit
WIFES
660 RHINO CAMO 28INCH VAMPS
DADS
03 660 wetlands camo
snorkle,rad relocate ****s on all 4, 29.5 outlaws on ss112 sra wheels
600 grizzly backup
RE: 660 front drive shaft? - 7/25/2008 4:34:12 PM
YAMAFORD
the engine side has a snap ring on the shaft so you need to put the shaft in a vise and use a punch to hammer the internal part of the cv off the shaft. the part # on the front cv is 789-66 and its made by NTN but I couldnt find anything on line. like I said, goto a cv shop.
MINE
04 660 black
WIFES
DADS
600 grizzly backup
(in reply to YAMAFORD)
RE: 660 front drive shaft? - 7/27/2008 10:13:00 AM
Greg G
ORIGINAL: GrizzWise
Call turner and talk to them about the custom mod they do to the grizz front drive shaft.  they can explain it way better than I ever could but I will say this, for almost the same money as a new drive shaft, I sent them my old one and they worked on it, sent it back, and havent had a problem out of it since.
Greg G
'04 Yamaha Grizzly, HMF, DynoJet, KnN w/ProDesign, Tamarack Box, Yamaha Windshield, custom cooler holder, Hella lights, Warn 2500 & bumper, HL rims 28x12 MSTs, HL springs, 1.5 in lift soon
05 BigBear, RidenRest seat back, mesh rack extension, 27x9,27x11 Titan M/T, ProComp lights, ITP type 6 rims coming soon.
http://s221.photobucket.com/albums/dd94/mpdxtreme/
(in reply to GrizzWise)
RE: 660 front drive shaft? - 7/28/2008 7:12:45 AM
03 Grizz
I got a used one from a friend and got it put in saturday.  It seems to be fine now.  I may send my old one off later to someone to beef up because it isnt broken just got a busted boot.
2003 Yamaha Grizzly
Warn front bumber
(in reply to Greg G)
RE: 660 front drive shaft? - 7/28/2008 10:48:41 AM
rokke17
ORIGINAL: YAMAFORD
ORIGINAL: rokke17
My boots are fine, but the axle stub is wearing out at the tranny end.  I was driving around slowly in the driveway with the side panels removed and it wobbles very bad.  I can wiggle it around with my hand also.  I want to get the shaft warranted before it expires.
"Red"
07 Grizz 660
Warn Winch
27" MSTs
HMF Penland Pipe
RE: 660 front drive shaft? - 7/28/2008 1:57:41 PM
benitslu
someone told me they can fab something up to lengthen the shaft. that is where a lot of problems come into play.
i need to work on mine now....
05 Grizz 660
blk ss 212's
28" gbc gators
mudslinger tranny snorkels
temp guage
milk crate on da back rack!
0.859
