Tan327
If you remove all TM and do not do anything to beef up the transmission, at least add more line pressure. GWC, the TB bypass takes less than 5 mins to do. Remove your intake tube from the TB, on the front bottom of the TB you'll see a hose going to it, and a hose going out of it on the drivers side. This is there to heat up the air going into the throttle body to prevent it from freezing in REALLY cold climates. The hose coming out of it on the drivers side runs to the block (I think? It may runs somewhere else, it isn't very long). Remove that hose, you won't need it. Now, take the other hose and run it to the block (or where ever it goes). This hose is quite a bit longer and should reach, you may have to re-route it though. You should not have any hoses going into the throttle body now. Sorry if that is confusing lol, you can also disconnect the hoses from the TB and connect them together with a barbed union, that is a little easier to explain. Who knows if this mod even helps any, you probably won't notice it with the seat of the pants meter, but why not have your air as cool as possible?
08' Can-Am Outlander 800 - Stock for now! 07' AC 650 H1 - Sold!
