LIL GUIDOU
THE KIT COMES WITH THE PISTON ,GASKET, AND SLEEVE. YOU WILL NEED TO REMOVE AND BORE OUT CYLINDER AND ALSO PULL ENGINE AND SPLIT CASES TO GRIND EXCESS FOR CLEARING. A CAM DOES NOT COME WITH THE KIT,BUT YOU CAN GET ONE FROM WEB (88 OR 956 GRIND). DEFINITE IMPROVEMENT IN POWER, WITH NO OVERHEATING ISSUE WITH STOCK RADIATOR IN STOCK LOCATION.
YAMAHA 450 KODIAK (2006) K&N FILTER/HMF PIPE/DYNO JETKIT/BAYOU SNORKELS EPI CLUTCH KIT - ORANGE SECONDARY,COMP STALL 488 BIG BORE KIT/ 956 WEB CAM 2" HL LIFT WITH HL SHOCK SPRINGS HL TEMP GUAGE 27" OUTLAWS ON XL2 RIMS
