joshua99ta
call high lifter... add a big bore, camshaft and a clutch kit to the bike... it will make a big difference. I assume you have a pipe already? where are you located? Some machine shops will not do it b/c ya have to cut the stock cylinder out a little to make the new sleeve fit but it comes with direction of how much needs to be cut out. With a little measuring any good machine shop can do it. I believe the clearances are .003-.004 between the cylinder and sleeve. When ya have the cylinder honed out make sure they check the piston size... mine was 3.672 and the specs said to put the bore @ 3.681... which would leave .009 between the piston and the sleeve... JE(maker of the piston) recommended .002-.003 so my machinist put the sleeve bore @ 3.675 I probably confused you by that but if you have any questions feel free to pm me
98 Foreman 400- Tan 31" laws on machined XL2s getting some much needed improvements 08 PoPo RZR 800, 2" HL Lift, HL springs, diamond plate, winch, 28" Zillas on Chrome 14" SS112's, kick **** sterio and a permanent beer cooler 05 suzuki 'Busa on RC Compenents "OUTLAWS" www.myspace.com/joshua99
