Calcote
I search through pages of "will it turn them" and "where can I buy one", so I am giving up and just asking. I have the TRX300 primary and secondary gears. I know how the primary goes on. My question is about the secondary gear. Do you have to remove the stock secondary, and attatch the TRX300 clutch basket gear to the stock foreman clutch basket? Or do you swap the whole TRX300 clutch basket, gear and all? Have you guys bin pulling the motor to do this or doing it with the motor installed? Anyone have a link to a good technical write up on this? Side question. How do you get the engine to top dead center when the pull start cord is removed and pluged? Pull the cover and turn manually?
1994 Honda 300 Weisco high compresion pison, 102 Web cam, uni filter, jet kit, clutch kit, Cobra exhaust, custom front disc brakes, High lifter 2" lift, Warn 4-2-4 kit, black ITP wheels, snorkle, 27" Laws and a new gear reduction 1999 Honda 300 uni filter, FO-14 exhaust, 26" vampires 2004 Honda 450 Foreman Wesico high compression piston, Foreman 400 w/ stage 3 head job, HL clutch kit for Big Bear, polished carb.
