366 2nd clutch mod
366 2nd clutch mod
All Forums >> [OEM Discussions] >> Arctic Cat >> 366 2nd clutch mod Page: [1]
366 2nd clutch mod - 8/19/2008 4:30:58 PM
squirrel500
http://www.highlifter.com/forum/Secondary_Cage_Mod_for_the_700_EFIs%2c_05-06_650_H1s_%26_500s/m_2783142/tm.htm
This mod will also work on the 366. i ended up just truning the uper plate clockwise a round and tighten it back up. The helix is diffrent from the ones on the bigger cats. It has alot more holes to chuse from and a ring with rollers around it. Ill get picks later.   But I wonder if it will have the same performance.  Due to not change the hole.
2006 A/C 500m
26" 589s
2" rear lift
That all I will say on line
Hard Pack Arctic Cats
It all seems HardPack when you ride a CAT
2002 Honda recon 22" swampwitch
FMF ext
snorkel K/N
08 366 lime green with 26s 26s too big went back to 24" Why did A/C put 3.1 in the new quads?
THANK YOU STEEL HORSE. YOU KNOW WANT YAL DID. KEEP UP THE GOOD WORK
RE: 366 2nd clutch mod - 8/19/2008 5:20:41 PM
FRANKP
I took 2 rollers out of the front and on the rear I turned the plate counterclockwise about 180 degrees moving the spring hole and turned it clockwise till the keyway was lined up Top of the belt sits a little higher on the rear. And I do like this mod. I have 27' tires and 4.0 gears, but now when I kneel on the seat I can get the front tires about a foot off the ground in high. I couldn't even get them to come up in low before the clutch mod. Later Frankp
(in reply to squirrel500)
0.125
