30s on and floating..lol?
All Forums >> [OEM Discussions] >> Arctic Cat >> 30s on and floating..lol? Page: [1]
30s on and floating..lol? - 8/24/2008 12:45:24 PM
Went rideing yesterday and put on my 30" mudlites 10s and 12s because its pretty dry at our local park, Really like how smooth these tires are and what mud we found they walk right threw not like a law or anything but do well, they climb very good over downed trees and up hills pretty happy with them.
My gauges all worked real nice and where there at they are real easy to see without even taking your eye's off the trail real happy with the location on them.
Sodbuster let me ride his 500m and spray it a couple times  i have to say my 650 will be getting a N.O.S. kit installed on it at some point..lol
Main thing with these 30s is they will float my 650H1  we found a spot about 50' across with a solid bottom that was chest deep to ride threw and i followed Sodbuster threw it and noticed it looked deeper on his quad then mine he has 29.5" laws , well i started to notice that mine was feeling real tippy and i had to give it alot of throttle (because i was not moving) to finialy get the back tires to drop down and touch the bottom and once i did that i seen how deep the spot was and it was alot deeper then my gauge pod but yet it never went under my racks went under about 3" but going along level like i was my snorkels should had been the only thing sticking out..lol
Just thought it was funny that my heavy "butt" quad was trying to float with these 30s on it, never had done that before with my laws on..  So if you got 30s and hit some deep water hang on..lol
ok done rambling on.
08 650H1 LE
Warn 3.0
Snorkeled,Rad relocated
Custom mounted gauges
muffler tweaked
Custom clutch kit, 4.0 gears
"G" axles
29.5 Laws on custom LE wheels
30" MLs on Black Castle Roks
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
26" 589MTs on ITP type 6s
Hard.Pack.Arctic.Cat
RE: 30s on and floating..lol? - 8/24/2008 12:57:58 PM
bustedknuckles
What air psi are you running? Might need to lower it a bit....lol
click here and buy my suburban
"APE AXLE"
STEELHORSES
CATVOS
08 ThunderCat
08 650H1
(in reply to GWC)
RE: 30s on and floating..lol? - 8/24/2008 1:01:50 PM
i have 3 or 4psi in the rears and like 6psi in the fronts, i would lower it more but with the side walls on these tires being so soft i think they would roll over to far and come off the bead..?
might just have to it some more hambugers..lol Iam only 165lbs and thats being wet..lol
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
(in reply to bustedknuckles)
RE: 30s on and floating..lol? - 8/24/2008 1:19:41 PM
BrokenKitty
Man i wish you got pics !
PINNEN AINT EASY....
_07 650 h-1_
- Tall snorkels
- Rad up top
- Wide open on 26s for now
- 2 " lift kit
- Highlifter springs
- axle spacers
- Dalton clutch kit
- Hmf muffler
- K&N an jetted
- Front brush guard
- Rear brush guard
- 3000 lb monkey winch
- Handle guards
http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=333810678
http://s218.photobucket.com/albums/cc75/Gwar918/pinnd/
(in reply to GWC)
RE: 30s on and floating..lol? - 8/24/2008 2:19:03 PM
JOHN PAUL
no pics!!!!!!!!!
GOLDSBORO POWERSPORTS
RACING #88
07 ARCTIC CAT 650 H1
29.5 LAWS
HMF PIPE
JETED
SNORKED
RAD RELOCATED
MOTOSPORT WHEELS
CLUTCH MODS
IT ALL SEEMS HARDPACK WHEN YOU RIDE AN ARCTIC CAT
(in reply to BrokenKitty)
RE: 30s on and floating..lol? - 8/24/2008 2:33:08 PM
wetKITTY08
ORIGINAL: GWC
i guess i better start lining me up a fat girl to come ride with me when i get my 30s cause i weigh 140
I Practice Safe Riding I Pull Out Every Time!
08 650 H1
12" polished SS 106s
12" MSA Torx
28" S-Backs(sold)i'm ridin stockers at the moment
HMF
Radiator Relocate
Snorkles
Dyno Jet
Mods to come:
Filter
4.0 Diffs
4"CATVOS
29.5s or 31" Outlaws
07 Honda 420 rancher
the hunters special
83 Honda Big Red
Can't destroy this **** thing
no matter what i do.
(sold)99 Honda 450 Foreman 4x4
http://www.myspace.com/dwanger08
(in reply to GWC)
RE: 30s on and floating..lol? - 8/24/2008 3:15:22 PM
exklueziv
yea my H1 would float on 30 mls too.  it was wild! The clearance you get on those bad boys is great too.  It didn't matter how much pressure I ran in em they would float forever.  You have to watch em though if you run em below 5psi.  they are pain in butt just to get em to seal on the rim to begin with.  I bet the 14" wheel would have a different effect on the floating though if you put them with a 30Ml
'06 Arctic Cat Six-Fifty H1 LE (FOR SALE)
SS 112s 14inch wheels on 27 mudlites
28X9.5 OUTLAWS
Clutch kit
Dyno Jet kit
Snorkeled
HMF pipe
HL springs
Gaxles with 2"lift
Rad remounted on top
And I have a TRV with a 10 inch lift
(in reply to wetKITTY08)
RE: 30s on and floating..lol? - 8/24/2008 3:25:01 PM
badakodiak
my 650 h1 would float when it got about rack deep with 29.5x10's on it and i weight 170lbs, but i took the air pressure down from 15lbs to about 4 and i like they way the laws pull alot more w? 4lbs in them
WILDCHILD CUSTOMS BOG TEAM
TEAM H.P.A.C
2008-artic cat 650 h1 black
k&n
ngk
hmf
2" lift
hl springs (powdercoated silver)
21" of GC
ss 212's
29.5 laws
slide mod
clutched
2007- brute force 750i candy blue
law'd
lift'd
snork'd
k&n'd
2004 kodiak 400 4x4 auto
2"hl lift kit
custom dual snorkels
28" EDL's
moose rear rack
ngk spark plug
2.5 warn
www.myspace.com/wildchildcustoms
(in reply to exklueziv)
RE: 30s on and floating..lol? - 8/24/2008 3:28:35 PM
exklueziv
yea I like 5psi in my laws.  they always find the bottom and keep rollin on
28X9.5 OUTLAWS
Clutch kit
Dyno Jet kit
Snorkeled
HMF pipe
HL springs
Gaxles with 2"lift
(in reply to badakodiak)
RE: 30s on and floating..lol? - 8/24/2008 4:05:31 PM
yeah i never had my 29.5 laws float on me before wel not like this anyway it was kinda crazy lol , shoot with my laws if you just pop the throttle the back will go down and you start a water wheelie i had to almost go WOT at one point because the back would not pull down and i and was just surprised..
yeah no pix we were just to  busy riding.
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
RE: 30s on and floating..lol? - 8/24/2008 8:11:15 PM
kingcat500
Heck i can get mine floating sometimes with my 28's
Its fun floating when you get the hang of it.. but you move REAl slow
2005 650 H-1
hmf
TALL snorkles
re-jetted
relocated radiator.
28inch laws on xl2's
28inch lites on LE's
Hard Pack Arctic Cat
"it all seems hard pack when you ride a CAT
(in reply to GWC)
RE: 30s on and floating..lol? - 8/24/2008 8:22:25 PM
700Blaze
From: Washington MO. home of B&J CUSTOM FABRICATION
yea they get alittle tippy in deep water
"700 CAT"
FULLY CUSTOM BUILT BY
MY SPACE-----MY PHOTOS
THE BOYS OFFROAD CLUB
(in reply to kingcat500)
RE: 30s on and floating..lol? - 8/24/2008 9:24:11 PM
Muddin_dude05
My Grizz would float  with my 27x12 Mud B's all around once it got about 4' deep, was kinda surprising the first time it happened lol. I haven't had a chance yet to try with the Laws, I have been riding by myself  this weekend
(in reply to 700Blaze)
RE: 30s on and floating..lol? - 8/24/2008 9:44:39 PM
exklueziv
I had 30x12s for about 6months after my bevel gear went; and I got used to being able to float across ponds and creeks. then when I put laws back on it was hard to get used to them going to the bottom.  I thought I was sinking everytime.  But I will tell you what tire will eat you lunch is 28x10 EDL's.  Those tires do not float and they dig and dig and then they dig some more.  That tire needs WOT and you can get through any mud, but if you creep it like you would with outlaws they are gonna stick you at the bottom.  I rode on some recently and I can see why they are good in the pit.
28X9.5 OUTLAWS
Clutch kit
Dyno Jet kit
Snorkeled
HMF pipe
HL springs
Gaxles with 2"lift
(in reply to Muddin_dude05)
0.891
