29.5 swamplite vs 30 mudlite
All Forums >> [Most Popular Discussions] >> Tire Talk >> 29.5 swamplite vs 30 mudlite Page: [1]
29.5 swamplite vs 30 mudlite - 9/27/2008 11:02:04 PM
greencat06
which tire is better in mud and which one is better in water.  Been trying to trade my 28 laws for mudlites but not having any luck.  Just wondering how the swamplite compared to mudlite. Thinking bout trying to find some swamplites since i am not having any luck on the mudlites.
Thanks
08 700h1
29.5 swamplites on black ss212's
snorkeled
speedwerx
1.5 wheelspacers
RE: 29.5 swamplite vs 30 mudlite - 9/28/2008 5:05:15 PM
honda3004x4
MY opinion, swaplites dont clean out very good in mud, I would get mudlights they seem to work better and clean out better.
97 Honda 300
bbk
cam
jet kit
gear reduction
K&N
28 laws
trooper m7 wheels
wheel spacers
lift
locker
custom pipe
snorkel
axle paddle
custom oil cooler
Coming soon
warn 4-2-4
highlifter springs
high compresion piston and new cam
new axle
redo snorkel
(in reply to greencat06)
RE: 29.5 swamplite vs 30 mudlite - 9/28/2008 6:47:50 PM
wiseguy90
I would have to disagree I have swamplites on my rhino and a buddy of mine has mudlites on his rhino and did a comparison between the two and the swamplites were superior in the mud but in the sand and on the trail they were about equal.
Camo 06 Yamaha Rhino 450, 27" Swamp Lites, Douglas, Rockstar wheels, 2" Highlifter lift, K&N 3" Billet Intake, 2" Exhaust tip, 3000 Warn, Full Skid Plates, MS MUDD Snorkel kit,
WCA stero system
(4 sound stream 5X7's on a 400 watt Powerbass amp)
http://www.msmudd.com/homepage1.html
(in reply to honda3004x4)
RE: 29.5 swamplite vs 30 mudlite - 9/28/2008 7:20:03 PM
BruteForce20
Have you thought about going 29.5 Outlaws? I think you would be happier with 29.5 over the Swaplites and Mudlites
07 Black 650 BF
Chip
Intake
Power Commander
Center snorkles
HMF
HL 2"lift
HL Springs
31" Outlaws
14" Motosport alloys
1 1/2 Spacers
Audio Pipe " JAMZ"
San Anglo Backrest
"Cooler full on the back"
98 Honda Recon - Stock
92 Timberwolf - Stock
(in reply to wiseguy90)
RE: 29.5 swamplite vs 30 mudlite - 9/28/2008 7:31:50 PM
AlaskaCub
ORIGINAL: wiseguy90
I agree with that statement and it is weird because looking at the lug pattern on the Swamp Lites you would think they dont clean very well but nothing has been further from the truth . I took my KQ and ran it through all the same places around my house I had been running the Mudlites through and the Swamp Lites performed much better than the mudlites did. There is something to ponder though, we all live in different regions and the term "mud"  is defined different everywhere.
< Message edited by AlaskaCub -- 9/28/2008 8:29:33 PM >
08 King 750 AXI, 26" SwampLites on Black SS108's ,Warn 2500 Winch,Twin Air, EPI Yellow spring, 18 gram weights,Coop Primary shim Mod, Precision Racing Steering Stabilizer, Suzuki Rear Bumper, Suzuki Front Rack Extension,Moose Front Bumper, Kolpin Rear Box, Cabelas front Bag, Kolpin Gun Boot, Amsteel Blue Winch Rope
RE: 29.5 swamplite vs 30 mudlite - 9/28/2008 7:54:35 PM
greencat06
I am trying to get rid of my 28 laws because i ride mostly trails and i broke an axle in reverse and it was not cause i have a heavy thumb.  I just wanted to gain a little ground clearance by going bigger but less aggresive so i wont be out to break stuff so easy.
08 700h1
snorkeled
speedwerx
1.5 wheelspacers
(in reply to AlaskaCub)
RE: 29.5 swamplite vs 30 mudlite - 9/28/2008 8:26:09 PM
gotmud08
imo, i would go with the 30 ML. they have a 1.3inch lug if im not mistaken and you wont have to give up much in weight with the ML. if your worried about strain on your bike witch im thinking you are since you mentioned breaking an axle with your laws i would strongly consider the lighest of the two since your going up so much in size... just my thoughts
08 honda foreman (camo)
28' laws (skinnys all 4 corners)
clutch kit
2inch lift
dyno jet kit/k&n
1.5' spacers
HL springs
hmf exhaust
snorkled
RE: 29.5 swamplite vs 30 mudlite - 9/28/2008 8:59:10 PM
greencat06
thanks i had 28 mudlites on my 500 arctic cat and rode it pretty hard but never broke anything. What is the weight difference in the 29.5 sl and the 30ml?
08 700h1
snorkeled
speedwerx
1.5 wheelspacers
(in reply to gotmud08)
RE: 29.5 swamplite vs 30 mudlite - 9/28/2008 9:19:22 PM
Well if you ride any deep water the mudlites are not the tires to get, IMOP mudlites and Swamplites are to close to call in mud, i have had both ride with a guy that has 29.5 SL and i have 30" MLs and are tires are to close to realy say one is better then the other in mud neither are great mud tires but with some work both will get you threw.
I bought mudlites because they are very light and work well in sand, swamplites are heavy and dont work well in sand at all. both climb good ride nice .
08 650H1 LE
Warn 3.0
Snorkeled,Rad relocated
Custom mounted gauges
muffler tweaked
Custom clutch kit, 4.0 gears
"G" axles
29.5 Laws on custom LE wheels
30" MLs on Black Castle Roks
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
26" 589MTs on ITP type 6s
Hard.Pack.Arctic.Cat
RE: 29.5 swamplite vs 30 mudlite - 9/28/2008 9:22:34 PM
kingquad300
he's right THEY SUCK OUT LOUD IN SAND had some wally world tires on a 160 that would do better lol
but SL's will air up to 31in or at least mine did but around here we try to float so we genrally run more air pressure...
Main Ride: Izzy
Grizzly 600
belt snorkled
motor intake snorkled
oil cooler re-locate
HMF (Polished)
carbonfiber fan overide switch
2 Inch lift front and rear
Jetted (Again and again and again)
oil temp guage
wheel spacers (1.5 inches all the way around)
bored 40 over
29.5 Swamplites on sum full moons
pull'en them w/o a clutch kit
split stero (2 6 1/2's & adding 8 incher fo that thump)
(in reply to GWC)
RE: 29.5 swamplite vs 30 mudlite - 9/28/2008 9:37:51 PM
wiseguy90
I would also have to disagree with the sand issue ...I ride the creek a pretty good bit and have no problem in the sand I mostly stay in 2wd while others keep locked in 4wd so that they dont just sit there and dig and go no where...now I dont know if this is due to the rhino's weight playing a factor in it or not but thats my personal experience
WCA stero system
(in reply to kingquad300)
RE: 29.5 swamplite vs 30 mudlite - 9/28/2008 9:40:51 PM
Ok i mean dry sand, did not mean wet sand there is a big difference as wet sand clumps together to help it be more "like" mud. in dry sand like at the "dunes" they suck bad...lol
jmop
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
0.594
