rangergirl
REQUIRED ATTIRE JERSEY/LONG SLEEVE SHIRT HELMETS - DOT APPROVED/MOTORCROSS HELMETS ONLY EYE PROTECTION GLOVES BOOTS PANTS/ "NO BLUE JEANS" - NO SHORTS Engine sizes based on Manufactures marketed units. 0-500cc 2x4/4x4 ATV (marketed as) Tires marketed and made for ATV or RUV use only. No Tracks, paddle tires, automotive tires, or agricultural tires. Up to 3” shock bracket lift or shock pipe lift. Factory frame, a-arms and a-arm locations, swing arms, trailing arms and stock length axles. Must use original factory engine mated to particular unit. Must use stock or aftermarket shocks allowing suspension to travel. Engine modifications limited to jet kits, air filter, performance programmer’s, exhaust and big bore kits. Basic retail parts available to drivers may be used. 501-990 2x4/4x4 ATV (marketed as) Tires marketed and made for ATV or RUV use only. No Tracks, paddle tires, automotive tires, or agricultural tires. Up to 3” shock bracket lift or shock pipe lift. Factory frame, a-arms and a-arm locations, swing arms, trailing arms and stock length axles. Must use original factory engine mated to particular unit. Must use stock or aftermarket shocks allowing suspension to travel. Engine modifications limited to jet kits, air filter, performance programmer’s, exhaust and big bore kits. Basic retail parts available to drivers may be used. OPEN CLASS Tires marketed and made for ATV or RUV use only. No Tracks, paddle tires, automotive tires, or agricultural tires. Must use original factory frame and any ATV/RUV engine mated to particular unit. Additional Engine modifications such as alcohol, Nitrous Oxide Systems (NOS), superchargers, turbo systems and big bore kits are allowed.. ATV’s may not exceed 6’6” in width and 8’6” in length. Production and custom suspension lifts, extended A-arms, extended swing arm, extended trailing arms and other modifications are allowed. No hydraulic steering or hydraulic powered transmissions or drive train. RUV Class 0-990+cc 2x4/4x4 RUV (marketed as) Tires marketed and made for ATV or RUV use only. No Tracks, paddle tires, automotive tires, or agricultural tires. May use factory engine from any ATV or RUV. Passenger must be 16 years of age or older. Engine modifications such as alcohol, Nitrous Oxide Systems (NOS), superchargers, turbo systems and big bore kits are allowed. RUV may not exceed 18” over stock in width or 18” over stock in length. Production and custom suspension lifts, extended A-arms, extended swing arm, extended trailing arms and other modifications are allowed. No hydraulic steering or hydraulic powered transmissions or drive train. Driver and passenger must remain in seat during race. Only under severe rollover circumstances may a driver or passenger exit the RUV.(Rollover or crash) Overall Rules Each ATV or RUV is Limited to one participating class ATV’s may not compete with RUV’s in same class. All vehicles must have a form of retrieval attached. Tow hooks, winches or tow ropes will provide a means for rescue. Drivers may race up a class but not down a class. Starting positions will be determined by random drawing of lane position numbers. We reserves the right to place drivers in correct class if driver registered his or her vehicle in the wrong class. False starts will be recognized by placing the driver one ATV or RUV length behind the other drivers on 1st offenses. 2nd offenders will be disqualified. Drivers must keep their machines inside of marked race course at all times during the heat. Drivers who exit the race course will be receiving a black flag. Drivers, spectators or any other persons may not intentionally touch or aid any other driver during a heat. Stock or production aftermarket fenders are required. Fenders may be trimmed up to two inches. Ski’s and utility attachments to units are not allowed. (plows, seeders, etc..) Sign –up times Friday 2pm – 5pm Saturday 8am – 11am Rides meeting and staging will start 11:15
< Message edited by rangergirl -- 9/22/2008 4:52:38 PM >
700 GRIZZLY RZR TEAM CREEK BOTTOM #19 DRIVEN BY MUDDERS MAG OFFROAD POWERSPORTS MORE MUDD www.creekbottomtrailrides.com www.moremudd.com
