bocephus660
Mudstock 2005 me and kleinwild sank it 3 times in the buddy run lol.. I had a 686 kit and cam put it in and it would never hold a set of rings.Tried 3 different piston, rings,and cylinders.I never had the cases split and cleaned out the first time and the oil passages and pump pickup were clogged and engine was not oiling.Thats why it wouldnt run 10 minutes without smoking lol.Took and had everything in the entire motor replaced. New crank,rod,.20 over stock yamaha piston,new cylinder,new head,new stock cam,rockers,valves,springs,every chain in the motor,basicly everything except for the cases is brand spankin new.I even had em put all new bolts in on all the topend cause they were stripped out from takin it apart so many times.I wanted it right this time cause I was sick and tired of wastin time and money puttin a bandaid on a gunshot wound lol.It runs like a charm now as it should.The reason the suspension is from an 07 is because I had a gorrrilla lift on it and sold it to a guy with an 07 and we just swapped my suspension onto his and his onto mine.
TBC RACE TEAM ODB/FCP Brute,08 Teryx,02 Eiger "Good things come to those who wait..BUT..Only the things left behind by those who hustle" http://www.flickr.com/people/bocephus1/
