C1iffBurton
not that part number i gave you...when u get home and look at the bike, get on the left side of the bike and look at the top left of the carb, its on the left but its on the upper half of the carb where the cable goes into the carb, there should be like some sort of goofy looking rubber or plastic piece that kinda looks like a bell in a way, then a nylon nut that has threads that go into the carb, if im not mistaken where the cable goes back and turns towards the carb there is a hard either metal or plastic tube that is around the actual cable and the end of that fits into one of those two pieces i mentioned above, if either one of those is broken itll allow the cable to pull out enough to cause it to stay opened or at least opened up somewhat to allow more stuff through than it should be i guess is how it is if u got any questions just pm me
MINE*08 big bear 400, 27" skinny black love outlaws, CRSbear custom snorkel, Gumbo03 custom lift, oil cooler relocated, fan switch, audiopipe, viper 2500 max --TEAM ANYTING GOES RACING-- R.I.P. JAYSON MATTHEW PARKER
