2004 1/5 stalling NEED HELP
All Forums >> [OEM Discussions] >> Polaris >> 2004 1/5 stalling NEED HELP Page: [1]
2004 1/5 stalling NEED HELP - 8/30/2008 10:43:12 AM
Never Stuck
I want to know if anyone else has had this problem on there sportsman. I had just replaced a ecm on a 04 1/2 sportsman 500 because it had a battery draw & it also flashed the hot light on the pod all the time but the fan worked fine. After I changed it, it started to stall out at any time, seemed to be worse when hot. It would allways restart but sometimes it took a while. It could stall out so many times that you couldnt ride it 20 feet without it stalling at least once. I did some testing & found that when it stalls it looses spark. Did more testing & found when it did die there was no pulse from the CDI to the coil, so its not the coil! Did more testing & found powers & grounds are good to the CDI. I measured the resistance of the pick up at the CDI conector & it was allways at 222ohms & I tryed testing as soon as it stalled & it was allways 222 but as soon as I pluged it in it would start so I dont know for sure its the CDI. I allso tested the throttle switch & its open all the time, wires are ok I dont think this could cause the stalling. Any suggestins?
< Message edited by Never Stuck -- 8/30/2008 10:46:02 AM >
Keep the rubber side down!!!
RE: 2004 1/5 stalling NEED HELP - 8/30/2008 10:44:20 AM
Never Stuck
I should add I have a CDI coming, but for $330 I would like to be sure befor I plug it in!!!!!
(in reply to Never Stuck)
RE: 2004 1/5 stalling NEED HELP - 9/1/2008 11:44:08 AM
Never Stuck
Somebody must have a suggestion?
RE: 2004 1/5 stalling NEED HELP - 9/2/2008 5:15:29 PM
aczr2k
Check the routing of the spark plug wire, there was an issue, some were improperly routed between the gas tank and the frame, shorting out the wire.
RE: 2004 1/5 stalling NEED HELP - 9/2/2008 7:12:09 PM
libertypolaris
the pick up or trigger coil on the stator is suppose to measure 97ohms +/- 20%.  you should try replacing the trigger coil. they sell it by itself.
(in reply to aczr2k)
RE: 2004 1/5 stalling NEED HELP - 9/2/2008 7:19:16 PM
Never Stuck
Thats what I was trying to find out. Can you get a oem trigger coil by itself, or only aftermarket?
(in reply to libertypolaris)
RE: 2004 1/5 stalling NEED HELP - 9/2/2008 7:40:55 PM
libertypolaris
polaris sells them by themselves here is the part number 3089254
RE: 2004 1/5 stalling NEED HELP - 9/2/2008 7:51:09 PM
Never Stuck
Thanks Ill check into it. Do you know how much of hand?
RE: 2004 1/5 stalling NEED HELP - 9/2/2008 7:56:27 PM
libertypolaris
I think they are less than 50 bucks, but honestly i don't remember
RE: 2004 1/5 stalling NEED HELP - 9/17/2008 9:00:04 AM
Never Stuck
Is that part number good for 04 1/2 & newer 500's? I want to be sure it will fit because they are bacordered till nov!!! I know this parts from a 05 will work as well. Thanks libertypolaris this is very helpfull!
RE: 2004 1/5 stalling NEED HELP - 9/17/2008 8:47:00 PM
libertypolaris
as far as i know it is the same part on all carbed 500s
RE: 2004 1/5 stalling NEED HELP - 9/17/2008 8:54:04 PM
Never Stuck
Thanks I just wanted to be sure!
RE: 2004 1/5 stalling NEED HELP - 9/18/2008 10:53:42 PM
younger
i had a very similar prob with my 03 600  it ended up being a shorted out coil in the stator  replaced the stator no probs since let me know wht it was or is
81 arctic cat pantera 580
1997 blazer 2dr
2003 polaris sportsman 600 twin
