12:1 compression h1 piston?
All Forums >> [OEM Discussions] >> Arctic Cat >> 12:1 compression h1 piston? Page: [1]
12:1 compression h1 piston? - 11/7/2008 5:16:47 PM
MUDTECHinc
I have been thinking about getting the 12:1 piston from speedwerx for my 650 H1 that i just put together has anyone ran this and how do you like it? what octane fuel can i run with this piston? 93? Also has anyone ran the PCP cam?
MUDTECHinc Custom ATV Fabrication Bog Team
2005 ARCTIC CAT 650:
29.5" Laws on Beadlocks
Web cam
2008 Arctic Cat 1000 H2
Carb slide mod
http://s226.photobucket.com/albums/dd185/MUDTECHinc/
Arctic Cat 650 H1 motor for sale $1800 plus shipping
Arctic Cat 500/ suzuki 500 ported head for sale $450 free shipping.
RE: 12:1 compression h1 piston? - 11/7/2008 6:17:29 PM
TBONESGRIZZ
I'm almost certain that you can run the 12:1 on 93 octane pump gas no problem.  Elaborate on the PCP cam because I am looking at this same setup for my 700H1...  Also, PM papa_slap... He has already done some extensive research thru CP and HotSeat on this setup I believe
< Message edited by TBONESGRIZZ -- 11/7/2008 6:21:19 PM >
'08 Polaris RZR - Project MonstR'
'08 Arctic Cat 700H1
'05 AMR Brute Force 650 SRA
TEAM THROWED OFF ROAD
www.myspace.com/msboyzridindirty
Driven By:
M.O.R.A
(in reply to MUDTECHinc)
RE: 12:1 compression h1 piston? - 11/7/2008 6:59:01 PM
MUDTECHinc
pcpoffrad sells a decent amount of parts for the 650 motor. they have the 670 11.5:1 compression big bore and a couple stock bore pistons. along with a cam that has .365 lift for 285 deg. which is alot more lift than the cam that I have in my 650 now. I am running the web cam out of the 500's and it is allright but I think it is pretty close to stock.
Web cam
Carb slide mod
(in reply to TBONESGRIZZ)
RE: 12:1 compression h1 piston? - 11/7/2008 9:23:45 PM
papa_slap
i don't think that cam is the one you are going to want to run with that duration and lift, it's angled more towards a mid to high range cam the one from speedworx is more of a overall range cam - low-mid-high rpm range.  JMOP.  I have the 11:1 speedwerx piston and it made a world of difference.  I am personally waiting for the speedwerx 700 bbk set up with the 12:1 ratio which would be borderline pump gas (93 octane).
resurrected: 05 black h1 "BIG BLACK",
it's got alitle bit!!
hers: 07 suzu fi, 450 "queen quad", 3"
xpatv, 28 swamplites on msa castlerocks,
2500 lb. winch yeah it spins them
team anyting goes racing
www.anytinggoes.com
RE: 12:1 compression h1 piston? - 11/7/2008 9:27:31 PM
  yeah waiting for that 700cc HC piston and cam
But to that one question 12:1 safe on pump gas..??  just seems like it would be to high for pump gas...?
08 650H1 LE
Warn 3.0
Snorkeled,Rad racked
Custom gauges
muffler tweaked
Dyna Tech CDI
Custom clutch kit
4.0 gears
HL springs, HL spacers
Gorilla axles
29.5 Laws, custom LE wheels
30" MLs, Black Castle Roks
05 500m
Hidden Snorkel
muffler tweaked
HL temp gauge
26" 589MTs, ITP type 6s
H.ard P.ack A.rctic C.ats
(in reply to papa_slap)
RE: 12:1 compression h1 piston? - 11/7/2008 10:26:31 PM
Black Cat 650
I know in the car world, 11:1 with aluminum heads is borderline for pump gas. Aluminum will dissapate (sp) the heat better than cast iron.
Scott
'07 Arctic Cat 650 H1 Black, Soundtube ATV stereo, Warn 2500 winch, ITP series 7 wheels, 27" Mudlights
Radiator relocated, snorkled..
'08 Fun Finder Xtra Toy Hauler
1 very understanding wife.....
(in reply to GWC)
RE: 12:1 compression h1 piston? - 11/7/2008 10:33:38 PM
yeap thats what i thought as well, once you get over that normal pump gas dont cut it just did not no if a quad motor was any different because some said you could run 12:1 on pump gas..
I still think iam going to get the 11:1 piston and then get s N.O.S kit and spray it as well..lol  just a small shot..
08 650H1 LE
Warn 3.0
Custom gauges
muffler tweaked
Dyna Tech CDI
Custom clutch kit
4.0 gears
Gorilla axles
05 500m
Hidden Snorkel
muffler tweaked
HL temp gauge
(in reply to Black Cat 650)
RE: 12:1 compression h1 piston? - 11/7/2008 10:33:41 PM
TBONESGRIZZ
Well there was someone in the Cat section that posted they were running 12:1 on pump gas with no problems.  You could run E85 or off the shelf octane booster if need be and still comply with HLPSR and CMR Pro B class rules I think as long as it's not "Race" gas...
Driven By:
M.O.R.A
RE: 12:1 compression h1 piston? - 11/7/2008 10:40:03 PM
papa_slap
I think you could run the 12:1 on 93 cause i can run my 11:1 on plus and it doesn't ping but it doesn't run as well as when i run super.
www.anytinggoes.com
RE: 12:1 compression h1 piston? - 11/7/2008 10:51:18 PM
Shoot those rules dont apply to me any, Iam to far away to worry about racing in the series i just want it for fun and to mess with people. lol
I just dont want to have to mess with buying race gas and all, now if it was at every gas station it would be different.lol
i got a 500 sticker on my pod and people allready freak out when they see it run thinking its a 500..lol
< Message edited by GWC -- 11/7/2008 10:56:01 PM >
08 650H1 LE
Warn 3.0
Custom gauges
muffler tweaked
Dyna Tech CDI
Custom clutch kit
4.0 gears
Gorilla axles
05 500m
Hidden Snorkel
muffler tweaked
HL temp gauge
RE: 12:1 compression h1 piston? - 11/7/2008 11:02:34 PM
TBONESGRIZZ
ORIGINAL: GWC
Haha I see how you roll Garrett! A "sleeper" bike! haha... I think 12:1 will be fine on 93 pump gas.  Anything over that such as 12.2:1 or 12.6:1 and I think your gonna be pinging.
Driven By:
M.O.R.A
(in reply to GWC)
RE: 12:1 compression h1 piston? - 11/7/2008 11:14:11 PM
yeah its got the "sticker mod" done to it..lol
also has popo shocks on it so you can tell its lifted because of no lift brackets so i tell people its all stock..lol
i want to put a nos kit on it and hide the bottle in one of my ammo boxes lol that will get them too.
08 650H1 LE
Warn 3.0
Custom gauges
muffler tweaked
Dyna Tech CDI
Custom clutch kit
4.0 gears
Gorilla axles
05 500m
Hidden Snorkel
muffler tweaked
HL temp gauge
RE: 12:1 compression h1 piston? - 11/7/2008 11:42:30 PM
TBONESGRIZZ
ORIGINAL: GWC
If you don't want a big shot go with the Sneaky Pete NOS system... It's only like 200 bucks
Driven By:
M.O.R.A
(in reply to GWC)
RE: 12:1 compression h1 piston? - 11/8/2008 12:12:38 AM
turbocoupe88
just because its a 12/1 piston doesn't mean your going to have 12/1.
that's all going to depend on chamber volume and gasket volume along with deck height etc.
09 700H1 mudpro
xentec 35w hid k5000 hlite conversion
29.5 10sx12s mtd on 08 le wheels
front/rear full size mrp racks
zeta handguards
works g series shocks duel rate with adj dampening/rebound
precision steering damper
warn 3000lb x2/rear winch mount
symtech htd grips/thumb/footwarmers,vest
whelen led strobes
50w rev lights (burners)
glacier 60in industrial plow
RE: 12:1 compression h1 piston? - 11/8/2008 12:38:37 AM
engie
You deal in alot of variables when it comes to "what can be compressed how much".  Ambient air temp, fuel temp, a/f ratio, rpm, initial spark advance, cylinder head volume, range of the plug used, etc...
No one number will work for everything or even every condition.  12:1 will be fine in the Cat motor though!  The stock spark timing isn't all that aggressive, imo...
Building a few motors with another innovation or two...
04 Eiger Auto - Going to Flynts' for vacation...
Parting out 06 Cat700...
A bunch of Eiger Parts and Can-Am clutches for Sale!
(in reply to turbocoupe88)
RE: 12:1 compression h1 piston? - 11/8/2008 1:47:20 AM
TBONESGRIZZ
Jarrett... What's the word on the pistons? Anybody else on board? If not I may just wait it out for HotSeat.  Lemme know... I got about a grand to drop in the 12:1, cam and clutching.  Got some c-locks on the way too I believe
Driven By:
M.O.R.A
(in reply to engie)
RE: 12:1 compression h1 piston? - 11/8/2008 12:11:53 PM
engie
ORIGINAL: TBONESGRIZZ
I have no fewer than 5 people wanting them right now...
Need to get it done!  After the first of the year, I dunno how much spare time I will have to help build it.  I'll have the entire month of december off...
RE: 12:1 compression h1 piston? - 11/8/2008 12:54:31 PM
engie
...and don't be BUYING any c-loks!  I already told you what we have to do there and am working on making it happen!  Going to build a prototype this week hopefully...
(in reply to engie)
RE: 12:1 compression h1 piston? - 11/8/2008 1:39:33 PM
So then everyone thinks 12:1 will be fine with pump gas.? and thats because it might not be a full 12:1 and has a none aggresize timing profile..  sound good to me,
08 650H1 LE
Warn 3.0
Custom gauges
muffler tweaked
Dyna Tech CDI
Custom clutch kit
4.0 gears
Gorilla axles
05 500m
Hidden Snorkel
muffler tweaked
HL temp gauge
(in reply to engie)
RE: 12:1 compression h1 piston? - 11/8/2008 9:58:47 PM
TBONESGRIZZ
ORIGINAL: engie
Well PM how much these c-locks your makin are gonna cost me!!! And also will they hold up under the RZR because I want to be able to swap them in and out.  Let me know asap so this deal I got don't fall through.
Driven By:
M.O.R.A
(in reply to engie)
RE: 12:1 compression h1 piston? - 11/12/2008 10:40:59 PM
TBONESGRIZZ
Bumping this post so that I don't clutter with a new one...
Anybody know if there is a 11:1 HC for the 700H1 yet?  Going a different direction with the Cat and don't really need 12:1
Driven By:
M.O.R.A
RE: 12:1 compression h1 piston? - 11/12/2008 10:43:58 PM
speed werx is not going to have theres out untill next year spring or alittle earlyer maybe. have not heard of any other yet myself.
11:1 is what i want for mine.
08 650H1 LE
Warn 3.0
Custom gauges
muffler tweaked
Dyna Tech CDI
Custom clutch kit
4.0 gears
Gorilla axles
05 500m
Hidden Snorkel
muffler tweaked
HL temp gauge
Post #: 22
RE: 12:1 compression h1 piston? - 11/13/2008 8:21:57 AM
papa_slap
I was told by speedwerx by the first of the year.
www.anytinggoes.com
(in reply to GWC)
Post #: 23
RE: 12:1 compression h1 piston? - 11/13/2008 8:37:09 AM
LOL to me the "first of the year" means early spring..
08 650H1 LE
Warn 3.0
Custom gauges
muffler tweaked
Dyna Tech CDI
Custom clutch kit
4.0 gears
Gorilla axles
05 500m
Hidden Snorkel
muffler tweaked
HL temp gauge
Post #: 24
RE: 12:1 compression h1 piston? - 11/13/2008 9:50:30 AM
Dreggsta
sorry to hijack but jarrett i know your'e realy busy working on stuff but any news on the wiring to reverse override for the 700 H1???
Team Southern Swamp Boyz
'08 700 H1 SE
Nology Coil & Wire
LE Front & Rear Bumpers
Big OG Racks
Warn 3k Winch
Powermadd Hand Guards
Moose Hand Grips by O.D.I.
High Lifter Springs
4.0 Gears
B & J Customs 2.5" Lift
ITP 14x8 SS 212's Machined Silver
Gorila Sliverbacks 30x11x14's On All Four Paw's
Rad Racked (MudTechInc)
Gorila Axles
Fully Snorked w/Pre-filter
Exhaust Mod & Snorked
(in reply to GWC)
Post #: 25
RE: 12:1 compression h1 piston? - 11/13/2008 8:42:30 PM
BLACKCATT
I don't want to wait for the 700 high comp. piston, so I might get the 14:1 piston for the 650 that speedwerx has and just mix some av-gas with it. I live 10 mins. from a small airport, so I can get av-gas as easy as when I used to drag race. I will get the web cam too, and wake the ol' cat up!
Any thoughts about the 14:1 piston, or the web cam? Chime in.
2005 650 H1 LE
"Original H1 Kitty!"
29.5 x 12 Laws on type 5s
4.0s
2" lift
Rad & oil cooler up top
2" snorkles & sealed
Clutch...
Drilled rollers
Secondary spring mod
Secondary cage mod
3.6 mm shim on primary (super low!)
Carb drilled & clipped
Gutted stock pipe & 2" exhaust snorkel
No more 8" lift = No more burnt boots!
(in reply to Dreggsta)
Post #: 26
RE: 12:1 compression h1 piston? - 11/13/2008 8:59:05 PM
14:1
i would be real interested to know if the stock bore 14:1 with a cam would make more HP then a 700cc kit with a cam (only stock compression)..???
I think maybe the 14: 1 but would it be reliable..?
what about the 670bbk with 12:1 piston and cam..??  another 29ccs is a nice amount..
08 650H1 LE
Warn 3.0
Custom gauges
muffler tweaked
Dyna Tech CDI
Custom clutch kit
4.0 gears
Gorilla axles
05 500m
Hidden Snorkel
muffler tweaked
HL temp gauge
(in reply to BLACKCATT)
Post #: 27
RE: 12:1 compression h1 piston? - 11/13/2008 9:21:13 PM
BLACKCATT
ORIGINAL: GWC
14:1
IDK... maybe I should just get the stock 700 and the web cam... nah!!!! I want some serious low end power! I will not rush in to the 14:1, I will get some more info 1st!
2005 650 H1 LE
4.0s
2" lift
Clutch...
Drilled rollers
Secondary cage mod
(in reply to GWC)
Post #: 28
