mfolkert
ORIGINAL: Matt_Mc Have yall heard of any one putting rear springs on the front? I have heard of a few people doing this around here. I think they are like $29 each. If I got a hmf Penland pipe, k and n and the hmf programmer orderd. Now I am reading that the hmf programmer is junk. Is this true? Should I sell the hmf programmer on ebay and get a power commander instead? The rear springs on the front was a fix for the XT models, not the base models. The XT's used a different spring set up on the front. The XT's used 2 springs and the lower short spring on the front many times, the coils were touching right off the showroom floor. If you look at your rear springs it will have two seperate springs, this lower spring on the rear is what guys were getting and replacing the lower spring on the front with. Yours, I am guessing is a base model and will not have the 2 seperate springs on the front. As far as the programmer is concered, Dobeck manufactures the HMF optimizer and markets this same model under several different names. The power commander is completely different and IMO much better. The HMF programmer you can only richen the mixture, which is fine if you are running lean but if you are already running rich, the optimizer is not going to help, if anything it will make matters worse. The power commander is capable of adding or taking away fuel so you can remedy either a lean or a rich condition. In my case, without a programmer I was already pretty rich, to the point I was loosing power, that is why I opted for the power commander. Power commander website has a few maps you can download for free and from my experience, was pretty close, to get it dialed in you will have to take it and have it tuned. trying to tune these machines with a programmer IMO simply does not work and the power commanders mapping program is just to complicated to even try unless you have the proper tuning equipment.
< Message edited by mfolkert -- 4/2/2008 12:40:41 PM >
06 Outty 800 MAX XT HMF Utility w/torque mod insert Power Commander Percision Steering stabilizer Works Pro G series shocks on all 4 Snorkeled 27 Mudgears on Climaxes 25 Bighorns on Black C-7s 2008 Yamaha Raptor 700 SE Barker duels Trinity intake and K&N Power commander
