07 popo 700 help
07 popo 700 help
All Forums >> [OEM Discussions] >> Polaris >> 07 popo 700 help Page: [1]
07 popo 700 help - 11/7/2008 11:29:27 PM
chrisw700
The bike will start up and run fine for a min then it will slowly idle down and finally die. if you give it gas it sputters and pops. both plugs are good and both plug boots are getting spark. the gas is fine. it is an EFI and NO CODES ARE COMING UP! help would be apreciated.
05 GRIZZLY AND ITS ALL TRICKED OUT!
TRIANGLE ATV-GOIN' DEEP
2004 TWIN PEAKS (sold)
http://community.webshots.com/user/chrissuzukitwin
http://www.youtube.com/chrisw660
RE: 07 popo 700 help - 11/8/2008 9:51:50 PM
contentsunderpressur
Sounds like the fuel pump.
03 700 sportsman SOLD
6 in monkey lift
29.5 laws
Progressive spring kit
relocated radiator
snorkeled
1.5 wheel spacers
fender extenders
08 800 sportsman (stealth)
Polaris rear bumper
05 Honda Foreman 500
stock with a snorkel
(in reply to chrisw700)
RE: 07 popo 700 help - 11/18/2008 4:06:58 PM
chrisw700
fuel pump has been replaced, the dealor has replaced almost everything. what are we missing
(in reply to contentsunderpressur)
RE: 07 popo 700 help - 11/18/2008 4:19:38 PM
REBELRIDER
Mine did the same thing. Its ended up being the MAF sensor. But mine DID shoot a code. Believe it or not, water was getting in there
< Message edited by REBELRIDER -- 11/18/2008 4:22:21 PM >
07' Polaris 700
29 Outlaws
AAEN
Snorkt' Through The Tunes
Visions
Keystone Light
RE: 07 popo 700 help - 11/18/2008 6:10:55 PM
Sportsman_Boss
A loose battery cable or a torn boot between the airbox and the motor will cause this with no codes
2005 sportsman 700 EFI, K&N filter, 7-100 watt off road lights, warn 2.5 c.i., Front lift, oxlite boot guards, front brush guard, 2.5" spacers on all four, soon to come: A-arm forward kit, HL 2" lift, 14" wheels, 31" outlaws.
www.myspace.com/brandonwinstead
(in reply to REBELRIDER)
RE: 07 popo 700 help - 11/18/2008 6:24:03 PM
TexasMudderBF650
I think it the maf sensor as well its located on the air intake out of the airbox check the wiring going to it for bare spots from rubbing on the frame.
2008 POLARIS SPORTSMAN 800 H.O.
6 inch lift, extreme products 1 1/2 spacers, 29.5 outlaws 10 front 12's back, stealth snorkels, 880 6000k H.I.D headlights
2005 BRUTE FORCE 650 SRA
29.5 Outlaws 10 front 12's back, EPI red secondary/ pink primary, Highlifter 2" lift, HMF exhaust S/O, dynatek cdi, Whelen strobes, k&n air filter, HL High capacity springs,
http://community.webshots.com/user/jcg4825
www.myspace.com/texasmudder
(in reply to Sportsman_Boss)
RE: 07 popo 700 help - 11/19/2008 4:56:04 PM
djhawthorn21
07 POLARIS 700
29.5 12 OUTLAWS ON ALL FOUR
VISION RIMS
SNORKLED THROUGH SPEAKER BOX
AAEN PIPE
RE: 07 popo 700 help - 11/19/2008 6:41:09 PM
142fast
I agree with Texasmudder it's really common . What all did the dealer do? just the tank and pump? Have all your grounds been cleaned? poor wiring  seems to be the norm on the 2005 EFI's
< Message edited by 142fast -- 11/19/2008 6:43:42 PM >
2005 700 EFI popo
28"Mudlites,and 29.5 laws
HC,
2" highlifter lift,
800 pri,
Team helix
epi sec spring
1" spacer in front,
1 1/2" in back
2002 500 camo popo
snorkeled intake for belt
27" Mudlites and she also rides my old stock tires from the 700
Check out what I've been up to here
http://4wheelingmn.blogspot.com/
(in reply to djhawthorn21)
RE: 07 popo 700 help - 11/19/2008 9:53:41 PM
chrisw700
it was the maf sensor, the dealor replaced the tps sensor, cleaned everything, and etc, fuel pump bla bla bla, he didnt think to check the maf sensor becuase it wasnt throwing a code. he replaced it and the problem is fixed.
(in reply to 142fast)
RE: 07 popo 700 help - 11/20/2008 7:42:13 AM
sweat800
Great to hear that it  is fixed. I think alot of dealers guess at what is wrong and start changing things untill they figure it out!
09 red sportsman 850xp EPS
front & rear bumpers
piaa front lights
warn 2500# winch
05 sportsman 800 SOLD
04 yamaha kodiak 400
2500# warn winch
RE: 07 popo 700 help - 11/20/2008 11:16:34 AM
TexasMudderBF650
  thats one thing i've learned in my line of work (electronic tech) is never trust the self test of electronics it won't always tell you whats wrong you have to do some troubleshooting.
< Message edited by TexasMudderBF650 -- 11/20/2008 1:48:10 PM >
(in reply to sweat800)
