Polaris425
2007 BF750 LRD Torc Exhaust SS108 SRA Rims (also comes w/ extra set of ITP IRS rims) 26x12 MST's on all 4 (Like NEW Condition, very little wear, if any at all) Custom Center Snorkels (can be removed if buyer wishes) & all vents are run up, including Crank Case. Hi-Comp Pistons & Web150i Cams installed by FCP (Flynt) Clutch set up: Currently has Red secondary from when I had the 29's on it, I have on the shelf a Maroon Primary/Black Secondary. Will leave in red if buyer wants to upgrade to larger tires, otherwise will go ahead and install new springs for the 26's. Oil has been changed after every ride where I was in nasty mud or crossing ponds, just to be safe. Since the motor work I've run nothing but Royal Purple in it. Also comes with (extra set of rims as mentioned) Primary clutch puller tool, 2" HL Lift kit, Stock exhasut, stock CVT and Airbox peices removed for snorkels. Only blemish on the plastics are some small groves on the left side where the pull rope burned into it when I was trying to pull start it, these can be seen in pictures. I dunked it once, not long after I got it. The motor was pulled, and taken to FCP for cleaning, and motor upgrades (listed above) so you know it was done right. Asking price is $6700. Resonable offers will be accepted via PM/Email. Location is Tuscaloosa, Al. Will drive max. 50+/- miles to meet buyer, otherwise buyer is responsible for taking delivery. pics can be seen @ www.MudInMyBlood.com/forsale.html
My '07 BF750 is for sell in the WTS section, or you can shoot me a PM "Play Hard, Pay Hard!" "Brute Force: On it, or Behind it"
